Thread: Boost gauge help
    redcar
    Default Boost gauge help
    When i bought my vectra 1.9cdti it had a boost gauge fitted and im just a bit confused if its working properly or not. The car seems to boost fine with no leaks etc. Heres a picture of it on idle
    As you can see it sits around 23 at the bottom numbers and when i put my fut down on full boost it goes up to around 12 on the bottom part of the numbers. It basically never goes below 10 towards zero.
    So is my boost gauge working properly and if so how do i read what boost its running
    Regular Member chrosty's Avatar
    Jul 2010
    lincolnshire
    i had the same problem with mine mate. i think you will find you have it connected to the wrong vacuum pipe so its not reading the boost correctly. which pipe is it connected to ? any pics of where it is connected then ill be able to see if it is where mine was connected before i corrected it.
    redcar
    Its connected to the left hand side of the bcs ill try and get a picture up later
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    thats right on idel does it go up when u drive it and floor it
    redcar
    Quote Originally Posted by paulvectrac View Post
    Yeah but when I floor it shouldn't it go on the positive top side of the numbers rather than the bottom numbers
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    That's right then mate
    redcar
    so even though its on the bottom side and is at 23 on idle and when i boot it goes up to 12 is that right?
    Heres a pic to where its connected, its the clear pipe
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    That's correct mate it measures vac on idle as there is no boost when idleing then when I drive or rev up the car will creat boost So it moves up the gauge
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    If the your car is a diesel you will not get a boost reading from there, you have to plumb into the large pipe coming from intercooler, You will not get a vacuum reading from a diesel either,, Here some reading for you http://www.vectra-c.com/forum/showth...ht=boost+gauge
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    well its measuring vac in that picture
  1. boost gauge
    By Swedge in forum Engine & Drivetrain
    Last Post: 15th November 2012, 00:53
  2. boost gauge
    Last Post: 24th March 2012, 12:25
  3. Boost gauge help!!!!!!!!
    By tomo41 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th June 2011, 17:36
  4. boost gauge
    By icetrix in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2007, 21:01
