Thread: warning light
    Sep 2010
    west sussex
    Default warning light
    hi....can anyone tell me how to get rid of the warning light in dash thats shaped like an engine .....cheers!
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    have the car plugged in to find out what fault is causing the light to be on , fix the fault , then plug in again & clear
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Or, if you've not got a fault reader, the most likely culprit will be the EGR and boost sensor. Give them both a good clean
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Agreed,
    I see you have a 1.9CDTi, so............
    If it is the engine light (EML / MIL) then the weakest components are sooted up / clogged EGR valve and boost sensors.
    There are How 2's on how to clean these in the Engine sub-section of the How 2 section (unsurprisingly).
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
