Thread: MAP sensor fault code
    Feb 2012
    Peterborough
    Default MAP sensor fault code
    Got a 1.9 cdti, started to get turbo lag so I cleaned the egr and the map sensor but now I get the engine light on and codes p010507 and p011011. Like an idiot i forgot to put the plug back on the MAP sensor, realised and refitted. Car drives great though. No limp mode just codes and light. Could I have damaged map sensor when cleaning?
    Marcus
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Personaly I would disconnect the battery for half an hour or so to reset the system and clear the codes,just make sure you got your radio codes BEFORE you loose it by resetting everything.
    Then 'if' the codes come back at least you know theere not old/stored codes from your forgetfullness.
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    did that on mine, took the airbox off and maf sensor, i turned the ignition on at some point and came on with the emissions light when i took it out for a run, once the car realised there wasnt an issue the light went back off..
    Feb 2012
    Peterborough
    Thanks, I did reset fault codes by disconnecting battery but they came back. I will run it for a while and see if it clears.
  1. Fault Code P1125 for both 1.9 CDTI's - Throttle Position Sensor
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 25th August 2013, 17:54
  2. Fault code 0340 Cam sensor malfunction
    By otto in forum Engine & Drivetrain
    Last Post: 28th June 2010, 13:55
  3. fault code help pls
    By pipe rodder in forum Engine & Drivetrain
    Last Post: 1st October 2009, 20:19
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. p0337 fault code crank sensor position a low>
    By rickyroo in forum Engine & Drivetrain
    Last Post: 4th May 2008, 12:20
fault code 010507
vectra c 1.9 cdti map sensor
vectra cdti 150 faulty map sensor
vectra map sensor fault
