Thread: MAF question - Y30DT
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default MAF question - Y30DT
    I had my car plugged in and thought I'd check all the values (fuel, turbo, coolant, etc.). I then thought I'd check the MAF values as well. When I revved the engine the mg/strk figure dropped, which is odd imo because the engine needs more air at higher RPM, or am I wrong here? I plugged in our 2.2DTi and the figure rose as I revved the engine...Do I have a faulty MAF sensor on my V6? I have to add that the fuel pump is failing, but I'm not sure if this would affect the MAF sensor...
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's not been stripped to be cleaned has it?
    And some how the element fitted in reverse?
    What was the voltage reading for maf?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I haven't removed it from the tube myself, but I'm quite sure it's in correctly. I would probably have some MAF fault codes stored if it wasn't.
    I'm not sure about the voltage reading, but I'm sure it was well over 2V under load. I'll check again tomorrow.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    It may not log a fault may just having running issues.
    If you have a. Multimeter I can give you the readings from mine to compare
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I didn't get the chance to check today mate, but could you still post the readings from yours?
  1. y30dt egr
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2011, 08:43
  2. Y30DT Fuel Filter Replacement Question
    By Antz in forum Engine & Drivetrain
    Last Post: 20th April 2010, 16:44
  3. oil filter question for y30dt engine(3.0 v6)
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 22:18
  4. Y30DT again
    By Celes in forum Engine & Drivetrain
    Last Post: 7th May 2009, 14:22
