Results 1 to 10 of 18
Thread: Driver's side window smashes. Should I try to replace it?
    Regular Member Barchettaman's Avatar
    Mar 2007
    Frankfurt, Germany
    Default Driver's side window smashes. Should I try to replace it?
    I made the mistake of leaving the SatNav mount on the windscreen and some scrote smashed the side window in the (vain) hope of stealing the TomTom.
    So, I have a Vectra without a driver's side window, and a Hoover bag now full of broken glass.
    The Haynes manual describes it as a 4 out of 5 spanner job, and you need a pop-rivet gun (which I don't have, but would buy) and an 8.5mm drill bit to remove the old rivet heads (where the ****** heck do you get an 8.5mm drill bit from)....
    I am mad to even consider taking this job on?
    In the past I've successfully removed doorcards, replaced doorhandles, front bumpers, pollen filters, etc as per Haynes, so I'm not a complete numpty. But neither am I Carroll Shelby.
    Many thanks all for any advice.
    Mar 2007
    Frankfurt, Germany
    Apologies, I tripped the swear filter. It wasn't that bad a word, honest.
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    get a quote from a car window call out place and check your insurance before you do anything, maybe cheaper easier etc to get someone in..
    May 2012
    northumberland
    woops lol forgot you aint in uk, surely you have similar insurance / autoglass types over there.
    Mar 2007
    Frankfurt, Germany
    Wow, thanks for the quick reply.
    TBH I'm not sure, will ring them in the morning -although German call centres aren't renowned for being open on Sundays.
    Obviously I want to avoid losing my NCB because that really is punitive over here.
    I've only had the motor 10 days. i s'post it's my own silly fault for leaving the mount on the windscreen, I'm so angry with myself at the moment. Grrr.
    VOTING UKIP IN AVELEY
    6 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Its really not that hard a job to replace the glass .
    But you should be covered on your insurance
    May 2012
    northumberland
    i once had a window smashed got a local comapny to fit a secondhand window pane, also the call out people should be 24hours, search one out local to you get a price, dont be shy to ask them to give a little money off if you use a local buisness.
    Mar 2007
    Frankfurt, Germany
    Cheers all.
    Vacuuming up window fragments is.... Not fun.
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's easy to change mate
    Mar 2007
    Frankfurt, Germany
    You reckon? I'm a bit worried about the drilling out of rivets and replacing them for the window regulator.
    I think I can get a replacement for about €50 from a scrappy.
  1. driver's side window dropped
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2012, 16:31
  2. Driver's window glass dropped
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th March 2012, 19:19
  3. Driver's window failure
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2009, 10:52
vectra c drivers side window glass
replacing drivers window vectra c
