Thread: cruise control in an automatic
    Jan 2010
    Hucknall, Nottingham
    Default cruise control in an automatic
    as the title suggests, i have a manual at the mo, and as expected the cruise control cuts off when teh revs dip below about 1000rpm. THe question I hae is this; does it do the same on an automatic car, or does the auto box just change down a gear to maintain the speed?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It cuts out mate well should do otherwise you will take off never tried it in mine lol
    Nottingham
    The auto box will certainly accelerate through the gears with cruise control on as I quite often hit the button coming off roundabouts and leave the car to get back to speed itself. Can't remember specifically but I think I can remember it changing down automatically on hills
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    He ssnt ask that I no what it does I have one he asked at low speeds does it cancell it's self at 1000rpm or lower
    11 Post(s)
    Quote Originally Posted by stripey View Post
    Sometimes can be a pain on small hills where you get a sudden surge when the box drops a cog on say a motorway. To stop it from happening I move the tiptronic lever to manual mode across to stop the box from changing down.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Often wondered about this but now we know! .
    Full Member Woody's Avatar
    May 2012
    North West (Warrington)
    168 Post(s)
    Vehicle : Vectra C 3.2 Gsi Auto (Zavoli LPG with Flashlube)
    Trim : Gsi with loads of "Extras"
    Engine : 3.2 Z32SE (LPG)
    Mileage : 131,000
    I'm lost here. Surely it's all about whether or not you hit your brake pedal (which will cancell your cruise control instantly). Other than that, it should maintain the setting you gave it. That is what cruise control is all about, set it, but the use of a brake pedal cancels it ? Well that's what my auto 3.2 does anyway and I wouldn't have expected anything else.
    Woody
    Jan 2010
    in a manual, the cruise control automatically shuts off when the revs dip too low (below about 1000rpm) I presume this is to ensure the car doesn't stall. My question has been answered, that in an auto box, if the revs dip to 1000rpm (like if you're going up a hill) then the box drops a cog to maintain the speed.
    Thanks for your help guys!
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    if you have cruise control on ,the car is very unlikely to drop below 1000 .not unless you have c/c set at 35 and are going down hill lol .but then again it will change down gears and you'll find yourself in 1st or 2nd. I personally am not that lazy and only use c/c when cruising at 70.
    Jan 2010
    I often use c/c on straight b roads so that i don't stray over the speed limit, but only having the 120 engine means that an sort of medium to large incline, the revs drop
  1. cruise control
    By vectra craig in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 13:07
  2. cruise control
    Last Post: 5th July 2012, 21:34
  3. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control Ha Ha
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2007, 22:40
