Thread: any ideas ?or is it just me !
    Aug 2012
    glasgow
    Default any ideas ?or is it just me !
    hi all it's my first post so be gentle lol i've just got a nice 53 reg 1.8 petrol club but the revs are very slow to come down between gearchanges and the cruise control keeps switching off every 2 mins other than this the car drives mint and is very good on fuel could these be connected ie clutch pedal switch ect or are vectras like this and the two are un connected any thought please ?and thanks in advance
    Jul 2011
    UK
    Year : 06
    My old vec b used to do that think was the throttle body thingy lol as for cruise clean the stalk where the buttons are
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    clean the throttel body out mate also the problem is the swith on ya brake pedal with the cruise control drive it put cruise on the pull the brake pedsal up with ya foot see if it stays on if it does needs a new switch on ya brake pedal also the 1.8 isnt that fast anyway mate big car for a small engine
    Dec 2011
    Seaham
    I understood they are designed to hold onto the revs to make the gear change easier?
    It is supposedly a design of the software to ease gear change and also burn of all fuel before its goes into the cat??
    Otherwise, how do I stop it?? Its really annoying.
    Aug 2012
    glasgow
    cheers for the suggestions guys i'll give it a clean out and check the pedal switch as for the 1.8 not being quick ! compared to my land rover defender it's a blooming rocket ship lol
    Regular Member 11mallard's Avatar
    Dec 2010
    Selsdon,Surrey
    Hi Kevin, I have a 2003 1.8 Club. Had similar probs. Found that the throttle body needed a clean with carb cleaner particularly where the small air bleed tube fits, mine was blocked solid and needed a pin to clear it. Same with the Cruise Control. Lay down in the drive side footwell and see if you have a large spring with a white plastic bit either end, on the clutch pedal, mine didn't but put one on and now perfect. As a check put your foot under the clutch pedal and lift it up and put CC on, if it stays on, you need that spring.
    Good Luck. Nigel
    Look at this in How2s
    http://www.vectra-c.com/forum/showth...-Clutch-Spring
    I did mine but didn't need to remove anything just a bit fiddly and awkward..
  1. Anyone got any ideas
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2011, 16:42
  2. Ideas Please
    By Tomb in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2010, 16:21
  3. Any Ideas ???????
    By johnnyd2003 in forum Engine & Drivetrain
    Last Post: 16th April 2009, 21:13
  4. Any ideas as to what this is
    By Baz07 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2008, 21:21
  5. Any Ideas?
    By steve in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2008, 16:49
