Results 1 to 10 of 20
Thread: Half canbus query
    crook
    Default Half canbus query
    I have changed my standard Siemens NFC 2013( burnt out) with a jvc double dinI have fitted leads to use steering wheel controls but they do not knock off the warning light for bulb off or low fluid etc,and I can not check mpg,range and that stuff now
    Is there a way of doing this
    Cannot even alter clock
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you will have to change the screen to a non NCDC compliant, and also get a wiper stalk.
    And move some wires (you can see in the how2 for retrofitting a ncdc to see what wires to move)
    crook
    the steering wheel buttons work the head unit ok
    Its the display, it doesn't come on now, it's on the screen you get when you turn your head unit off
    But mind doesn't switch on
    does the canbus connector need a live to it, because my canbus has no connections going to it now
    Engine : 2.2 Direct
    You need another screen. and a wiperstalk with the buttons on the end, to have a working BC again.
    crook
    Will vectra c stalk be ok and screen
    is it a hard job ?
    Engine : 2.2 Direct
    yes, well hardwork, that depends on your skills.. theres a little rewiring job to do, and tech2 to activate the stalk.
    crook
    Think I will sell jvc head unit and try and get second hand vauxhall one
    will any vauxhall head unit fit ie wiring the same ?
    Engine : 2.2 Direct
    Only another NCDC radio unite. And remember that will have to be coded to your car.
    crook
    **** lol
    so either way am going to need tech 2
    Is the stalk way got a how 2 for it
    Engine : 2.2 Direct
    yes you need tech what ever you do..
    what do you mean?
  1. half canbus to full canbus
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2017, 22:42
  2. Full Canbus - Half Canbus. Whats the difference?
    By M65 in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2013, 09:02
  3. HIDs with Half Canbus
    By M65 in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2011, 17:11
  4. Whats the difference between a canbus car and a half canbus car
    By chuckleuk in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 21:07
  5. Half CANbus/Full CANbus?
    By Ross DTi 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2006, 20:13
