Thread: loud squeal around 2k rpm
    Jun 2012
    Brechin
    Trim : Sri
    Engine : CDTi 150
    Mileage : 116k
    Default loud squeal around 2k rpm
    Hi guys SRi 150cdti owner here
    I was tootleing around town then when slowly accelerating back up to nsl I noticed this squeal, just get loud up to about 2k then stops again only on like 1/2 throttle kind of area. Any idea what that could be? doesn't need an oil change but I'm going to do one anyway.
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    possibility something caught in the dust guard on your brake .
    squeals like a pig and very loud .
    Jun 2012
    Brechin
    Trim : Sri
    Engine : CDTi 150
    Mileage : 116k
    bump,
    any one have any other ideas? bit more info...
    This started the other night when only using 1/4 to 1/2 throttle (aka taking it easy) there's a rather loud and annoying squeak that comes from the engine (turbo?) At around 2k rpm and fades off after that, only does it when taking it easy and not when its getting thrashed
    Any one got any ideas what may be causing it? Oil level is fine and doesn't require a change but I'll do one anyway
    im worried its the turbo bearings to be honest car is on 103k
    Jan 2012
    Silverstone village
    Have you checked the auxiliary belt isn't slipping and then squealing like a pig?
    Normally noticed when you blip the throttle.
    May 2006
    scotland
    Is your aircon on or off? If on, it may be the aircon.
    Jun 2012
    Brechin
    Trim : Sri
    Engine : CDTi 150
    Mileage : 116k
    belts arent slipping and it isnt the air con, only does it under load and its a very high pitch
    Nov 2010
    Warrington
    Have a poke at the swirl flaps. If there's some vertical movement, boost can bleed off, possibly creating the squeal you describe.
    When was your manifold replaced - if it's still the original on 103K, good going ;-)
    I'd expect more of a hissing sound from a leak in any of the pipe-work.
    BB.
  1. Got Squeal ??
    By wardy23 in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2012, 22:42
  2. 314 break squeal help!!! really loud and annoying
    By Big Red in forum Suspension, Wheels & Brakes
    Last Post: 29th February 2012, 12:01
  3. Brake squeal
    By Samdy Gray in forum Suspension, Wheels & Brakes
    Last Post: 19th December 2011, 10:22
  4. Brake Squeal
    By yoclick in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 19:32
  5. squeal
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2007, 20:57
