Thread: normal voltages after alternator replacement?
    Feb 2011
    Default normal voltages after alternator replacement?
    After the advise here, I changed the alternator on my 1.8 vectra, very happy I was with myself.
    I have done some meter readings after a drive and when the engine is off the battery reads 13.4 volts and when running the reading is 14.9 volts.
    Do these sound right ? the old alternator was 12.5 volts with engine off and 14 when running. So there is definitely a difference and the limp home mode and power steering problems have gone away now.
    scotland
    Your readings certainly sound a bit high to be honest! Are you using the same multimeter as before? A 12v battery has 6 cells at 2.1 volts per cell so it really shouldnt be much over 12.6v fully charged, 11.7v is fully discharged.
    Lead acid really does not like being charged at more than 14.4v so your 14.9v might be in danger of damaging the battery if the voltage measured is accurate.
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    When I measured my 1.8 vvt running it was pumping out a steady 14.7 volts.
    No adverse effects here so far
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Battery is shorting a cell internally
  1. Alternator pulley - replacement has finally arrived
    By Caveman_nige in forum Engine & Drivetrain
    Last Post: 21st July 2017, 18:32
  2. Replies: 0
    Last Post: 8th December 2011, 22:15
  3. 2.0T Alternator replacement
    By neilbroad in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2011, 11:35
  4. signum -alternator belt replacement
    By mike a in forum Engine & Drivetrain
    Last Post: 22nd September 2010, 18:14
  5. Oxygen Sensor Heater Circuit Voltages?
    By marcdale in forum Engine & Drivetrain
    Last Post: 31st May 2009, 21:28
vectra c 1.8 correct alternator voltage
