Thread: removing and fitting rear diffuser
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Default removing and fitting rear diffuser
    Hi folks. My rear vxr diffuser back from paint today.
    Just wondering, do I need to take the bumper off to remove the Sri diffuser.
    Also the vxr one doesn't have the holes for the tabs at the side like the Sri one. Will I still new ones or?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    I didn't remove my bumper when I fitted my last one, but it would be easier if it was removed (mainly when its bonded on). I put holes into the ends, and used some plastic grommets to keep it in place.
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Sounds like a plan. kinda hoping i dont have to take the bumper off, as easy at it is. Will line her up later and pop a few holes in and use the old grommets.
    Thanks for that.
    Murdo
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by MURDO View Post
    Thanks for that.
    Murdo
    Like I say, I didn't remove mine, and I used to masking tape to keep it in place while it dried.
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    So did you put holes in the outer tabs and then bond it on, put in the grommets and then mask til it set.
    Will araldite do the job, used it on the eybrows and seemed to be pretty good stuff (to date).
    Lancashire
    Trim : XP1
    Mileage : 66000
    Yes, thats what I did - I used some silicone adhesive, you can get that from most motor factors.
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    K. Diffuser fitted. however the old sri lugs from the bumper are still there.
    Am i gonna have to remove cut them off. Can see them sticking out slightly behind the exhaust holes. Was a bit to dark to take any pics. Will get some up tomorrow.
    Didn't glue it into place yet. want to make sure it's sitting right first.
    Going to have to re-align the exhasuts as they seem to close to the outer edge of the diffuser. Maybe new exhaust mounting rubbers...
    Thanks for help Dan, appreciate it..
    Murdo
  1. Replies: 5
    Last Post: 5th February 2012, 20:42
  2. Fitting vxr rear diffuser to sri xp
    By 2.2 oil burner in forum Styling
    Last Post: 18th July 2010, 11:55
  3. Fitting VXR Diffuser
    By coddy2200 in forum Styling
    Last Post: 18th May 2010, 16:57
zafira vxr rear diffuser removal
Rear Diffusers
vectra c rear diffuser
vectra rear diffuser removal
removing vectra c rear diffuser
fitting vectra vxr rear diffuser
opel vectra c rear diffuser
vectra vxr rear diffuser fitting
astra h vxr diffuser removal
vectra c remover rear defuser
renive rear defuser vectra c sdi
how to remove astra h vxr diffuser
fitting vectra vxr diffuser
vectra c diffuser
