Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: (Possibly FIXED!) I'm running out of ideas now (1.9 CDTI 150 low power until 2000rpm)
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Default (Possibly FIXED!) I'm running out of ideas now (1.9 CDTI 150 low power until 2000rpm)
    Ever since I bought my car i've been disappointed with how dead the car is below 2000rpm.
    As soon as the car hits 2k it's off like a shot and with a cloud of black smoke.
    Since I bought it, it's had
    A new inlet manifold
    New Vac pipes
    The throttle body has been cleaned, cleaned again and i've even driven the car with the throttle body disconnected.
    The egr at first was cleaned, then unplugged, then software deleted and then blanked and it's made no difference.
    All of the boost pipes covered in fairy liquid but there are no leaks - anywhere.
    Umpteen fuel cleaners
    New air filter
    The bcs stripped and cleaned
    Another bcs tried
    The maf stripped and cleaned
    A known working maf tried
    But still the problem persists. I am now onto the theory that the VNT actuator may be sticking (read alot about this on various VAG forums) and i'm led to believe that the vec shares it's turbo with one or two of the VAG diesels.
    Anyone come across this fault? If it is the actuator then I think it's time to change the whole turbo and actuator to cure the fault.
    It's really depressing me now as the car just feels amazing when the boost eventually comes on
    West
    I note you have replaced the vac pipes, have you tested the vac solenoids to check they're working as they should
    Nov 2009
    newcastle
    Clean/remover the turbo control sensor. Sorted my problem at 1-2000 rev.
    Its the grey/white sensor on slam panel. Filter is under the black hat. Un-click it first b4 removing filter as its permanently fixed.
    Theres a thread on it few days ago.
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Boost sensor could do with cleaning as geordieric states. I notice is missing from your list. lol. Actually ignore what i just said, you got it under bcs lol.
    Nov 2009
    newcastle
    There's 2 sensors. One which I mentioned which restricted my lower rev range only it seems. The one on back of engine block hampers the whole rev range(I clean that one once a month or whenever I'm playing. Vectras are so much fun
    South east
    Quote Originally Posted by John IS3 View Post
    VNT means variable geometry turbo (or variable nozzle turbo to stay true to the acronym). Are you certain the Z19DTH turbo even has variable geometry?
    West Midlands
    I'm watching this thread with interest. You've got the same problem as me an I've tried most of what you have, apart from cleaning that sensor on the slam panel up, only removed the mesh filter off it!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Are you sure the Vacuum pump isn't to blame?
    South east
    It looks like you do indeed have a VNT:
    http://garrettbyhoneywell.com/produc...w.php?id=75228
    Jan 2012
    Gloucestershire
    As GazCDTI150 says, is your vacuum pump working correctly? This pump is responsible for producing the vacuum that pulls the turbo wastegate actuator. So, even if your vacuum pipes are ok and the boost control solenoid is ok, if insufficient negative pressure is being produced by the pump the actuator may not function as it should.
    However, firstly I would jack up the car, remove the turbo actuator hose and get some clean hose (4mm ID) and suck on it. You should be able to see the actuator rod pull in against its spring (with a torch probably) with little sucking effort. This could at least show you that the actuator is moving freely enough to be pulled in. If this moves freely, then maybe your vacuum pump is struggling or you have a leak/BCS problem you have yet to find. If not, maybe the actuator rod is stuck.
  1. No power & very lumpy running 1.9 cdti
    By phil147 in forum Engine & Drivetrain
    Last Post: 19th June 2013, 17:25
  2. cdti running really lumpy and no power??
    By richiem in forum Engine & Drivetrain
    Last Post: 7th July 2010, 19:16
  3. modified hose fixed turbo lag and no power cdti
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 22:41
  4. My turn for no power under 2000rpm in Vectra CDTi (150) SRi
    By Ollie in forum Engine & Drivetrain
    Last Post: 27th March 2010, 18:40
  5. what should the power be like under 2000rpm
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 16:30
