Thread: Cdti 150 starts and stalls
    Jul 2012
    Ireland
    Default Cdti 150 starts and stalls
    I have recently bought a Vectra Cdti 150 that sometimes starts but then stalls straight away only first thing in the morning when It's cold. Since I bought it I have changed the inlet manifold, blanked egr, intercooler, thermostat and housing and replaced the glow plugs but yet this problem.is still there and slowly driving me mad.
    Any ideas what it could be?
    Jan 2012
    Gloucestershire
    I think more info needed srbrian. How does the car drive once started? Any smoke on cold startup when it's struggling? Water and oil levels ok without topping up?
    Jul 2012
    Somerset
    Mightn't be much help but I had the exact same problem with the lorry I drive longer it was turned off the harder it was to start. It would run for a second then cut out. Anyway turned out to be injector sleeve. Could check your injectors. Like I say probably not much help but best of luck with it.
    Jan 2012
    Gloucestershire
    Yes, injector leakage was what I was thinking, although in your lorry it may not be common rail and so the leakage path may have been past the sleeve where the injectors are fed from the low pressure system and into the cylinder.
    Maybe a diagnostic leak test would be worth a shot?
    Jul 2012
    Ireland
    Quote Originally Posted by DieselWig View Post
    Once the car starts it drives perfect, no smoke or anything. It doesn't happen all the time, some mornings it will start first time without a struggle and sometimes it wont i have to try twice.
    Jul 2012
    Ireland
    ********UPDATE********
    Just an update after months of changing and checking everything turns out that it was the Camshaft sensor that was causing it, car starts so much better now
  1. 1.9 16v cdti sometimes starts very poorly when warm help plz?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 8th July 2012, 13:55
  2. Morning starts are ok - Afternoon starts are a ******!
    By Madaxeman in forum Vectra C / Signum Troubleshooting
    Last Post: 28th February 2011, 19:38
  3. CDTI Spanner light after cold starts
    By Teapot in forum Engine & Drivetrain
    Last Post: 30th December 2010, 00:02
  4. Vectra C starts then randomly stalls
    By Ardent in forum Vectra C / Signum Car Chat
    Last Post: 8th October 2010, 09:37
  5. 1.9 cdti (120) funny smell on first starts ?
    By Vectra-c-SRI in forum Engine & Drivetrain
    Last Post: 4th November 2008, 00:01
1.9 starts stalls vauxhall
