Thread: Airbag light
    Jul 2012
    Doncaster
    Default Airbag light
    My airbag light as come on since I removed the clocks for led conversion, I've read about and it seem like a common problem but there dosent seem to be any answer for getting rid of it.
    The fault cods is b0975-00 csd telltale circuit malfunction (shield seat detection)
    Hopefully some one can help
    Cheers Dan
    11 Post(s)
    Whatever the problem, it'll need to go on Tech2 or similar to have it put out.
    Jul 2012
    Doncaster
    Sorry forgot to mention when it's turned of via diagnostic it just comes back on?
    Any help would be appriectiated!
    Cheers Dan
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Take clocks out and make sure all pins on clock are ok and not bent, also do the same for plug.If all is ok and it still stays on after resetting only cure afaik is new clocks
    Irmscher Insignia CDTI 130
    Jul 2012
    Doncaster
    Ok will do if I need new clocks I won't be happy only got them couple of weeks back lol!
    Cheers Dan
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Did you check them before fitting ?
    Jul 2012
    Doncaster
    Just noticed a very slight difference in them which is the passenger airbag deactivation symbol next to the trip odo. This is not on my original clocks, so after a bit of research I've found that I need a transponder behind the dash!
    Does anyone know where abouts it's placed and what it looks like (pics if possible)?
    Cheers Dan
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    u didnt mention they arent the clocks you started of with, you said you removed them for conversion, so my answer was going to be to check the led's are soldered in correctly as this can cause that problem
    Jul 2012
    Doncaster
    The new clocks have the system for child seat disabling and the car asnt so I was going to try and fit a transponder reciever first as all the LEDs look good!
    If anyone can help me with the location of the module so I can get one from scrap yard I would be gratefull.
    Cheers Dan
  1. Airbag light!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 25th June 2012, 01:52
  2. Airbag light
    By Sharpy28 in forum Electrical & ICE (including SatNav)
    Last Post: 12th June 2012, 22:26
  3. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  4. Airbag Light
    By rocket999 in forum Electrical & ICE (including SatNav)
    Last Post: 18th August 2011, 16:22
  5. Airbag Light
    By Hollingsworth87 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th April 2011, 16:29
vectra c clock removal airbag light
