Thread: Dead instrument cluster
    Jun 2012
    Thamesmead
    Default Dead instrument cluster
    Morning people I got in the car yesterday and found that I have no instrument cluster so no fuel gauge or temp gauge no lights or nothing car still runs fine apart from this I got all lights and wipers and everything any suggestions what this could be or how easy it is to fix
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Unplug the abs plug spray some contact cleaner in it give it a few min the plug it Bak in
    Jun 2012
    Thamesmead
    Just tried that and nothing might give it another go later Cheers
    11 Post(s)
    Try preesing in the trip reset with the engine running.
    Happened to mine a while ago and came back to life with pressing the trip reset.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Pull out fuse 17 in the fuse box on the end of the dashboard, clean the connections on the fuse (or replace with a new one) and see if that sorts it
    South West
    As with ABS plug, remove steering wheel cowl, remove CIM connector, clean replace and see if that helps.
    Administrator plasma's Avatar
    On the Forum
    398 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by laney_2.2 View Post
    If your still on for Sunday I can have a look then... Location has changed a little (20mile) as having happypostie and bobthesignum round mine but sure we can do it then for you
    Jun 2012
    Thamesmead
    I tried the cim cleaning fuse is fine and tried the abs connector but still no joy I was told yesterday that it could possibly be that because the connections are dry soldered they have come loose and need re doing has anyone else heard of this as I've done a search on here but there been nothing about it
    Cheers plasma I'll see you Sunday mate where bouts are we meeting now
    Jun 2012
    Thamesmead
  1. instrument cluster
    By waky in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 00:31
  2. instrument cluster
    By veccyv6 in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2011, 19:03
  3. How do you remove the instrument cluster?
    By lee gsi in forum Bodywork & Interior
    Last Post: 27th May 2011, 21:23
  4. Instrument cluster
    By Daywalker in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2008, 18:43
  5. Instrument cluster
    Last Post: 12th October 2008, 20:02
vectra c instrument cluster removal
vectra c speedo removal
remove instrument cluster vectra c no codes
