Results 1 to 3 of 3
Thread: few problems n need some advice plz ta
    Apr 2012
    hampshire
    Default few problems n need some advice plz ta
    right, this is goin to be a bit long but will try and kept it sort as poss.
    toke my vx for a recall regarding the handbreak today to Evans in portsmouth( never used then before 1st) n at sometime i asked then to give a check allover the car n to plug the computer in, when left wasnt very happy, here is a list of the few problem:
    need front shocks ( no problem easy DIY job)
    need rear upper control arms ( should be a DIY job too)
    differential was excessive play , is this normal car has only done 113k from 2002, my wife drive the car most of times and she has told me about the gears not goin in easy, was goin to change the oil and see if it gets any better 1st. what type of oil do u guys recommend and how easy is it to change? if that doesnt work what other gearbox will fit my 2.2 dti if u guys know n is this a DIY job in the drive ( much be better then my alfa JTD that was a pain lol)
    now when they read the codes apparently was 26 codes stored in the system lol but only 3 was important:
    B0670
    B1375
    P0234
    can some1 help me with then plz
    i have goin to start looking around for way/how to fix all this little problems now but any heads up will be great
    thanks rick
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Would not worry at all about the dtcs early models always had lots of random codes and if gearbox isn't noisey wouldn't worry bout that either just the clutch getting a bit worn probably
    Apr 2012
    hampshire
    i need to do something about code p0234 as car does goes into limp mode a few times but i trough was coz of EGR valve but not.
    the gearbox does makes a crunchy noisey when gears go in. for example i was having troubles getting 3rd in today, i had to push hard/quick to get it in and not allways went in. will change the oil n see if makes any difference
  1. Tracking problems, advice please...
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2012, 22:43
  2. Thermostat and other problems maybe? Advice please!
    By daz1409 in forum Engine & Drivetrain
    Last Post: 3rd June 2012, 22:48
  3. Problems already...advice please!
    By Davies20 in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 15:25
  4. pinking problems?? advice please
    By dhallett1 in forum Engine & Drivetrain
    Last Post: 9th May 2009, 22:33
  5. Will the problems ever end??? Any advice welcome!!
    By marley in forum Engine & Drivetrain
    Last Post: 27th March 2009, 20:58
