Thread: Z20NET rocker cover removal
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Z20NET rocker cover removal
    Hi guys i i'm just wondering how hard it is to remove the rocker cover from my 2.0 turbo as i'm getting it powder coated, my questions are,
    1. do i need to worry about a gasket
    2. is it easy to remove
    3. are there things i should and should not do.
    Cheers in advance guys.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    It has a rubber gasket that you should replace, its an easy enough job but torque the bolts down in the correct order and to the right torque setting when you replace it.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Ok have you got the part number for the gasket and also what order and torque settings do i need to follow.
    Thanks for the response Nige
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    When doing this would it be be best to cover up the cams whilst it's away? I'd considered removing mine to be chrome dipped
    South east
    Rocker cover removal? There's no rockers on this engine, so no cover either. Cams only....lol
    Engine : Z20NET
    Lol, that's what I was getting at, the cam covers
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Im no expert on this engine but would like to know what part the top is with the oil filler cap sticking out of it i want to take it off and have it powdercoated can someone point me in the right direction please lol
  1. Rocker cover
    By Kenny_Exclusiv in forum Engine & Drivetrain
    Last Post: 6th September 2012, 10:31
  2. Rocker cover z20net
    By Iezzi-martin in forum Styling
    Last Post: 11th August 2011, 13:42
  3. Rocker cover 2.2 dti sri help please!
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2010, 23:59
  4. Vectra 3.2 Inlet / rocker cover removal
    By samarkh in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 10:58
  5. 2.2 Rocker cover (types) - Intake cover removal
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2006, 20:27
vectra c z20net turbo removal
