Results 1 to 10 of 23
Thread: went to toolstation for a aplicator gun and came out with a polisher
    May 2011
    bispham, blackpool
    Default went to toolstation for a aplicator gun and came out with a polisher
    as above was in toolstation today all i wanted was a aplicator gun for some silacone but looked in their catalog and seen this
    http://www.toolstation.com/shop/Sand...+180mm+/p84532
    now i know its a cheap and nasty thing but i thought for £40 i might as well try.
    so i got a sponge pad for compounding from a motorstore and had a play i used my spoiler as a tester as its not on my car so it didnt matter if i messed it up but it all seems good. heavy but good and easy to use.
    now i have a few questions.
    1, it has 6 speed settings starting from 600rpm upto 3000rpm i used speed 2 which is about 900rpm, what speed does it work best at.
    2, i know i have to keep the sponge wet am i best dipping the sponge in the water or have my hose pipe on mist and keep wetting the car.
    3, when i use the compound and i do a little section do i need to wipe it off stright away or can i complete say the roof then wipe it all off,
    also when im putting the liquid polish on do i put it on by hand and buff it up with the machine or can i get another round sponge adapter and put the wax on with that.
    any help will be greatful thanks
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    I have seen ones like this and wondered but for 40 quid more you can get a da and dont have to worry about ruining your paint or swirl marks as much lol
    May 2011
    bispham, blackpool
    Quote Originally Posted by Big Red View Post
    i wanted to buy one of those but didnt have the cash. and with this i thought if i can buy this and if i like it or more to the point if i can do it i can upgrade at a later date and sell the £40 one on ebay.
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    1, it has 6 speed settings starting from 600rpm upto 3000rpm i used speed 2 which is about 900rpm, what speed does it work best at. 1-3 will be for applying polish, 4-5 will be for cutting the paint or compounding, never use setting 6 it will be too fast and burn the paint its more for the bodyshop people
    2, i know i have to keep the sponge wet am i best dipping the sponge in the water or have my hose pipe on mist and keep wetting the car. Your better off having a spray bottle with water in it and spray each pannel lightly before you run the machine over it. If you had a DA you wouldnt need to do this step
    3, when i use the compound and i do a little section do i need to wipe it off stright away or can i complete say the roof then wipe it all off, Depens on weather conditions really, if its hot then id wipe it off asap if its a cool day/evening not sun then you could do the full panel. Your better of not doing it on a too hot day as the compound wont work properly.
    also when im putting the liquid polish on do i put it on by hand and buff it up with the machine or can i get another round sponge adapter and put the wax on with that. Put the polish direct on to the pad, you can do a circle of polish or pea size dots choice is really up to you
    May 2011
    bispham, blackpool
    thanks mark never thought about using a spray bottle.
    lets hope its not raining in the morning as im going to do it in the morning so its not to hot.
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Year : 2015
    Mileage : 3,200
    What pads have you got with it?
    Regular Member wardy23's Avatar
    Nov 2011
    North Yorkshire
    Vehicle : vectra
    Trim : sri
    Engine : 2.2
    Mileage : 64000
    think i might have to invest in one of these for that price
    May 2011
    bispham, blackpool
    Quote Originally Posted by Mark Evison
    It came with a big wollen one I think for buffing and a Sanding disk I just took it in to a car spares shop and said I want something that will fit so I can mop the car with mags compound. Their was 3 different ones that just screwed on to it so its perfect.also it has a disk with a hook and loop design so can get other pads for it. Going out at weekend to see what else I can get for it
    Sent from my HTC Wildfire using Forum Runner
    May 2011
    bispham, blackpool
    Quote Originally Posted by wardy23
    If I can get it all done tommorrow I will post some pics to show results good or bad
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Year : 2015
    Mileage : 3,200
    The big wollen one will be a heavy cutting pad to be used after you have wet sanded the car use it at your own risk! use foam pads only
  1. Car Polisher - Which one?
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 14:17
  2. da polisher
    By shb1988 in forum Detailing and Car Care Discussion
    Last Post: 20th March 2011, 10:03
  3. Polisher?
    By P3tchy in forum Detailing and Car Care Discussion
    Last Post: 17th December 2009, 23:03
  4. polisher
    By craigbarlow18 in forum General Chat
    Last Post: 7th February 2009, 09:50
  5. polisher??
    By dreadaz in forum Detailing and Car Care Discussion
    Last Post: 17th January 2008, 22:50
foam polish pad toolstation
