Results 1 to 10 of 11
Thread: Help Help Help Please !!!
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default Help Help Help Please !!!
    Hello Everyone .
    is there anybody near me in northamptonshire that can please help me remove this filler plug bung for the gearbox
    it is corroded in by the looks of it
    and is now starting to go round
    as i just cant get to it with the turbo being there
    i need somebody who knows how to get this off
    can anybody help me ??
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Few methods.
    - Try tightening it a 1/4 turn first as a rusted bolt will tighten easier then undo due to cleaner threads. If you get a tiny turn tight then wd up and undo.
    - Hammer in the next size torq bit.
    - Use hammer and chisel to open it up. Sometime i use the dremel to make a little groove in it for the chisel to grip.
    - Heat. Warm the thing up the try removing.
    - Big 16 side socket over the entire bolt head.
    - Use a dremel to square the hole the drive in a 1/4 or half inch extension bar and try to undo.
    South east
    Take it to a garage and get them to use their airgun with an extension.
    Mar 2011
    Northamptonshire
    anybody near me that can help ?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    where are you in northamptonshire?
    Mar 2011
    Northamptonshire
    Rushden
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Is your car off the ground at the moment?
    Mar 2011
    Northamptonshire
    no not off the ground ,but its in bits
    Jan 2012
    Silverstone village
    How crucial is it that this is done is it just routine maintenance?
    What size Torx/Allen is this?
    Can we have a wider shot of the location , just wondering what space or not you have to work with?
    Mar 2011
    Northamptonshire
    all fixed thanks to Merikiito
    excellent guy
    was not defeated by the bolt !!
    special thanks from all of us for the help
    Roger
