Results 1 to 10 of 19
Thread: broadband router
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    Default broadband router
    i think my wireless router has packed up.
    i can connect to the internet using home plugs through the router but i think the wireless part of it is toast.
    my laptop doesnt seem to find the signal anymore.
    is it likely to be fixable or is it new router time?
    and if so can someone recomend me a good one, doesnt need to be anything too flashy just work lol
    i am on virgin broadband if that helps
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Have you made sure that your wireless on the laptop is switched on? There is either a switch on the front of the laptop or you need to use a combination of key press to turn it on/off
    Can you see other wireless networks on the laptop?
    If not then its switched off
    Sep 2011
    Birmingham
    Trim : sri
    yeah the wifi is on, there is a button on the keyboard and i did turn it off once and wondered what had happened lol.
    it is on, will find other networks just not mine.
    same with mobile phone too
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Ok then turn off the router for 30 seconds and see what happens. My virgin superhub loses the wifi now and again
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Is it a virgin superhub? or a virgin supplied router?
    Sep 2011
    Birmingham
    Trim : sri
    tried that, the broadband was down from sunday till about tuesday then worked fine for one night on laptop and phones.
    then last night wouldnt work again, wont even find the signal now.
    i did try unplugging the router and the modem last night but it made no difference. i even tried resetting the router that didnt change things either.
    the router itself cant be completely ko'd as my skt+ uses homeplugs through it and that still works and my laptop works if plugged into the homeplugs
    Sep 2011
    Birmingham
    Trim : sri
    Quote Originally Posted by merikiito View Post
    tbh i cant recall where i got the router from, its a linksys but i cant recall if virgin supplied it or i did.
    the modem is theirs tho
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Maybe someone has turned the wireless off in the router, have you tried to go into the router settings?
    Sep 2011
    Birmingham
    Trim : sri
    someone would be me as its only me that messes with these things lol.
    i havent actually, will check that tonight.
    although that wouldnt really make sense because it worked tuesday night and i didnt touch the router again until it wouldnt work weds night. will check it still but doubt its that.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I have had a few linksys routers and they have packed up without notice so it may well be the router.
    when you get back turn everything off then turn the virgin box on wait 2 mins, turn the router on wait 2 mins then try and see if you can find the wireless
  1. Virgin Broadband Router Help
    By spennny in forum The 'Off Topic' room
    Last Post: 3rd June 2009, 08:17
  2. Best router
    By yorkshireborn in forum The 'Off Topic' room
    Last Post: 11th May 2009, 18:43
  3. Linksys Cable Broadband Router
    By stuart bigboy in forum General items for sale
    Last Post: 16th July 2008, 17:13
  4. What router do i need???
    By Auto-Brite in forum General Chat
    Last Post: 24th November 2007, 15:52
  5. Replies: 12
    Last Post: 29th November 2006, 10:17
