Page 1 of 8 123 ... LastLast
Results 1 to 10 of 80
Thread: The notorious travel assist base the definitive thread
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default The notorious travel assist base the definitive thread
    Just won one of these on the understanding that it will take a long time (if ever) to get the necessary parts to fit it to my Vectra.
    I've searched and searched for a definitive list of information on this subject and it's sketchy to say the least.
    I'm aware that Vauxhall don't supply the fitting kit anymore but for starters can someone post the part number(s) for the fiting kit (including base) for the Vectra C. I've seen the part number for what I beleive to be the travel assistant AND fitting kit.
    I know at least one name on here that has this correct number.
    Secondly, this base that is so hard to come by simply looks like a pressed piece of metal, surely if someone offered there's up they could be replicated by a fabricator fairly easily? I know of two fabricators up here who could carry out such a task.
    There seems to be plenty of availability on the travel assist units but not on the bases and fitting kits because people don't remove them from the car along with the unit, instead assuming the unit will fit any other Vec C/signum regardless.
    Thirdly what exactly is needed bar the unit itself to get this into a Vectra C.
    South east
    You seem prepared to go to a lot of effort to get one fitted. Will it be worth it? You'll get the majority of the same usefulness with an electric cool box from Halfords.
    Engine : Z20NET
    Thing is I don't think it's alot of effort at all, the electrics can all be DIY'd I'm sure uf It came to it I could knock something up myself as a base plate, just wanting to see what cones of this first.
    I like OEM novelty things, that is my reasoning for doing this
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Wasting your time mate imho. The fitting kit for the Vectra is even rarer than the Signum as the base is different.
    Your right that people do not remove the fitting kit as well including the little bolt type things that the unit fits into (you would need to get these /machined if someone will lend you one to copy).
    Give in now before you waste a lot of money and still don't get it fitted
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Kev_A View Post
    Your correct about the wiring but the base plate is very complex and you will not get one made without having an original to hand to copy. Even then it would be a huge task and cost a great deal of money
    Jan 2012
    Silverstone village
    This seems like a great idea, although not sure how much the base would cost to make.
    Exploded digram of the Travel Assistant
    Seems you mean part 19 in the diagram;
    19 Bracket, Tunnel, Console, Travel Assistant, Front P/N 13112958
    Do you need part 15 as well as the signum one has different hooks at the back into the seat, this is just what I have read.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The diagram does not include the fitting kit
    Jan 2012
    Silverstone village
    So what is included in the fitting kit?
    Travel Assistant fitting guide. 3/4 down page.
    Engine : Z20NET
    So do you have the base plate then the fitting kit with seperate part numbers?
    Is 13112958 definately the base plate for the Vectra?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Someone has posted up the part numbers needed several times before as they where available seperately but no longer I am afraid
  1. Travel Assist
    By DeathStar in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2007, 00:15
  2. travel assist
    By benny in forum General Chat
    Last Post: 12th September 2006, 18:07
how to wire the travel assist on a signum
