Results 1 to 10 of 23
Thread: Wiper Fault
    Jun 2012
    ayrshire
    Default Wiper Fault
    I have been digging around the net and even shelled out for a Haynes in an attempt to find fault with Wiper.
    Vectra C - 07
    Wiper Fault:
    Intermittent - No wipers
    Normal Speed - No Wipers
    Fast Speed - Wipers but no stop unless manual stop (its an art)
    Screen wash - only in fast speed and when wipers are moving.
    I have dug around relays and checked fuses, haven't dug in about the wiper motor.
    Any ideas on possible problem?
    Park sensor, Faulty motor, corrosion at motor plug?
    Any assistance would be very much appreciated.
    Stevie
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Stalk ????? All the things u list sound like they wud totally stop all operation
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Id say motor fault.
    But with you saying wash doesn't work it maybe the CIM isn't seeing signal from stalk
    Regular Member 130786howe's Avatar
    Nov 2010
    wales
    wiper motor had same prob cant explain washer jet though
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Wiper motor, as it isn't parking properly, it's likely theres a dirty connector inside the motor.
    Full Member Robsey's Avatar
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    Are there not two wiper motor relays in the under-hood electrical centre (UEC) - engine fuse box?
    I am sure that I have read a long time a go that one of the two relays failing, would give the very symptoms that you describe.
    Jun 2012
    ayrshire
    There are two of the same relay in the fuse/relay box.
    Sswapped them round and no change, that was my first guess was sticky relay.
    Is it easy enough to change the stalk, I was thinking of picking one up at scrappy / eBay before shelling out for a motor.
    Not parking, not working in intermittent or slow and jet was no op until you set fast speed.
    North East Cheshire
    10 Post(s)
    Trim : Energy
    Mileage : 131,000
    Hmm - have you done the basic electrical reset?
    Disconnect the car battery for 15 minutes or so..
    then reconnect the battery.
    If it is just an electrical glitch, then this usually sorts the issue
    This error occurs quite often on the Vectra due to the number of communications and modules involved in running the car.
    For those with half-CAN vehicles, make sure that you have you car pass number for the radio before you pull the battery.
    Jun 2012
    ayrshire
    Always a bit **** scared about removing battery connections from a Can operated car, simply for issues like the radio for one.
    I have a classic mini with virtually no electronics and can handle a power down.
    I will give the stalk a go, then dig about motor for possible corrosion at connections then go for a disconnect before shelling out for a wiper motor.
    Jun 2012
    ayrshire
    Defo not the stalk. New one arrived this morning.
    Swapped out the suspect one and no difference.
    If the suns out tomorrow I will have a dig about the motor.
  1. Rear Wiper Fault
    By lew1984 in forum Troubleshooting
    Last Post: 12th August 2011, 09:50
  2. wiper fault
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2011, 07:38
  3. Wiper fault
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 19:03
  4. Wierd wiper fault
    By Bobbyp in forum Electrical & ICE (including SatNav)
    Last Post: 16th May 2010, 18:26
  5. Strange Wiper Fault
    By lightfx in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2010, 13:47
vectra c wiper fault
