Thread: warning light
    Jun 2012
    Barnstaple
    Default warning light
    My car went in to the garage and has had a new alternator and battery fitted, when the car failed to start due to the battery being dead I had the spanner in a car light come on, i think this is the engine electrics light?! The light was still on when I picked the car up so I had it removed all the fault codes were minor things, but now the light has come back on so I'm just wondering what its likely to be? Car drives okay although it doesn't feel like 150bhp any body had similar problems? Constantly drive as I live in the countryside so can't afford to have the car off the road for a day all advice appreciated )
    Cars a 1.9cdti 150
    wirral
    49 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Needle in haystack mate
    Need codes read as their is literally 100s of possible codes.
    As its may or may not be related.
    Full Member Robsey's Avatar
    North East Cheshire
    20 Post(s)
    Trim : Energy
    Mileage : 131,000
    Hmmm -
    1.9CDTi 150 - yup a lot of possibilities.
    The spanner light is any "non-emmissions" related fault
    When the spanner light comes on, how long does it stay on
    a) On until the engine is started - A historic fault has been logged, but is no longer present
    b) Spanner comes on for approx 4 minutes then stays off - One of your glow-plugs is failing, or there is a potential wiring loom glow-plug controller fault
    c) Light stays on continuously - There is an on-going fault, which needs to be read off via any diagnostic tool.
    It is possible that the garage has failed to reconnect one of the connectors in the engine bay following the work on the alternator and battery.
    Jan 2012
    Silverstone village
    Check the MAF sensor is connected on the airbox?
    Aug 2007
    oldbury
    We have just fixed a similar problem - it turned out to be a split air tube coming from tubs near the radiator that influence acceleration; prior to that I'd been searching these forums for turbo repair hints.
  1. Warning Light
    By chrissy white85 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2012, 18:01
  2. Brake Light Warning Light
    By michaelangelo in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2011, 01:31
  3. Spanner light & 3rd brake light warning?
    By simp_2.2sri in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2008, 17:32
  4. Oil Warning Light
    By siz1 in forum Engine & Drivetrain
    Last Post: 26th November 2008, 20:03
  5. arghh side light problems warning light
    By Gregg in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2008, 21:58
