Results 1 to 3 of 3
Thread: Steering rack change
    Jul 2011
    Scotland
    Smile Steering rack change
    Last night I heard a strange noise from the passenger side and suddenly the steering went tight, I assumed I had a burst tyre, how ever after stopping to investigate found nothing, I decided to drive home albeit as carfully as one could. A later investigation found a large leak from the steering rack. Tonight I have disconnected the rack from car and just before I started to remove the heavens opened up, so the job did not get finished. Question I am asking is after all the usual bits are removed, ie track rods discon, pipes discon & the large bolts holding it to the car, does it come out easily, or is there other stuff I have to do, one post touched on dropping the sub frame ??, mine is a 2003, with the resevoir in the drivers wing.
    All help most appreciated
    I'm sure you have to.drop the subframe to get the rack out
    Sent from my GT-I9300 using Forum Runner
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Just drop the back 4 subby bolts then half undo the front 2 and lower the back end a foot or so. Comes out dead easy then via drivers side.
  1. Steering rack AGAIN !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 11:42
  2. Steering rack help
    By dittohead in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2011, 19:10
  3. Steering Rack?!
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2011, 12:17
  4. steering rack
    By gsi3.2Daveyg in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 20:54
  5. steering rack might be gone.
    By Darryl2.2DTI in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2008, 18:15
vectra c steering rack change
vectra c steering rack removal
vectra c steering rack replacement
exchange steering rack vauxhall vectra 1.9 ctdi
vectra 1.9cdti steering rack removal
vauxhall vectra steering rack repair
exchange steering rack vauxhall vectra 1.9 cdti
