Thread: changed interior lights, now none are working. :s:s:s
    Regular Member amand's Avatar
    Feb 2011
    west London
    Default changed interior lights, now none are working. :s:s:s
    cars a 56 plate, i decided to put some t10 led's in, yesterday i put two in to the main reading lights and today i thought id change them all. now none of the lights are working. is it a fuse? if so which one would it be.
    kind regards,
    Aman Dhanji
    Jan 2012
    Somerset
    When I did mine when I put the rears in it stopped them all working. Could only have them up front and I got some normal mtec bulbs to put in the rear
    scottish region
    Take them all out put standards back in and they will cone back on in 10 mins mate
    Regular Member montyfert's Avatar
    Jan 2012
    wales
    have you tried taken them out and turning them around .
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Firstly, check which way your T10 LED bulbs are fitted.
    They will only work in one direction.
    Then check that all the connectors are securely fitted
    and failing all that -
    have you checked fuse 12 at the end of the dash panel?
    Feb 2011
    west London
    i've tried changing the directions. ive checked the fuse. one light turns on but if i turn the back ones on it turns the front left light off. so its not a connection problem is it?
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    What kind off LEDs are you using? Standard or canbus with the built in resisters?
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Jun 2006
    St. Helens,Merseyside
    i had this when i fitted leds in the rear roof light.
    it was the pins connecting plus and neg on the same pins just front to back
    put a bit of insulation tape over 1 pin on each side of the led but on a diagonal
    i'll take one of the rears out later and get a pic to show what im talking about
  1. heator blower, interior lights not working
    By frenchman in forum Bodywork & Interior
    Last Post: 12th September 2012, 19:02
  2. Interior Reading Lights front and rear not working
    By Gavin Thomas in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 16:54
  3. help needed with interior lights not working
    By garethkett11 in forum Electrical & ICE (including SatNav)
    Last Post: 20th February 2011, 14:48
  4. Dash switch backlighting and interior lights not working...
    By Penfold101 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2009, 00:03
  5. dashboard and interior lights not working
    By raymondlhuk in forum Bodywork & Interior
    Last Post: 26th January 2008, 20:21
