Thread: Old SCV's
    Apr 2012
    midlands
    Default Old SCV's
    I will shortly be attempting to change my SCV's so two things really. Firstly does anyone have any tips/pitfalls? And secondly can I keep the old ones and stick them in an ultrasonic bath to clean them up in case I have to change them again or should I bin them?
    Thanks!
    Regular Member Johnny-B's Avatar
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    its problematic to screv out SCVs without removing pump, as in head are some bumps which mess to screw out, as I heard from mechanic than its need to modify some tool!
    Full Member
    Bristol
    It is possible to remove svc's without removing pump. one screw is a problem. So get a really sharp chisel and lossen the bolt then you can get on it with a hex head allen key. When you put new svc in do up the bolt as tighten as much as you can with the hex key and that it , the other bolts you can get on easy do it up tight and you will be ok. chuck your old svc away new ones are modified.
    Apr 2012
    midlands
    Ok cheers for the tips guys, just waiting for the parts to arrive now!
    May 2012
    Rīga
    Trim : Elegance
    Engine : Z30DT
    I found somm guys in China which offers kit with shipping for abowe 90 USD! Dontk know- price is sweet, but of course no info for produst quality!
    If some one is interesting I can give contacts!
  1. More on SCV's Quick answer please!
    By JonnyB_UK in forum Y & Z30DT Specific
    Last Post: 12th September 2012, 19:42
  2. Who can change scv's?
    By s2yob in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2011, 22:57
