Thread: Second Opinion...
    Regular Member Zeus^'s Avatar
    Sep 2011
    Grantham
    Default Second Opinion...
    Afternoon all,
    I know there are lots of threads about Boost/Vacuum Control Valves on here however. I just need a second opinion on this before I spent yet more cash on my Vectra...
    I have taken the valve off the car and stripped it down for a clean as advised by the How 2 and found these...
    https://docs.google.com/open?id=0Bwe...GxJMEpxNHRKODQ
    https://docs.google.com/open?id=0Bwe...mtMYkRwZXAxZ1k
    Am I right thinking that the cracks would cause the vacuum to be weak. Thus affecting the actuator on the turbo meaning that my wastegate never quite shuts?
    Might explain my pesky 100bhp only problem :-/
    All thoughts are appreciated!
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    can't view the pics mate, i guess the viewer needs to have a google/gmail account or something like that
    Sep 2011
    Grantham
    Odd...should be setup for public viewing?
    To summarise the pictures. The cracks are along the top of the unit where are the part code is. Does that help at all? Lol
    Sep 2011
    Caerphilly
    Vehicle : saab 93 tid(150)
    Trim : sport
    Engine : 1.9 z19dth
    Mileage : 63000
    The cracks dont that deep in the pics and if i remember correctly when i dismantled my bcs there is a metal shaft inside where a pin fits into and i think its internally sealed anyway BUT to be safe i would clean the area and use normal glue blobbed onto the cracks if that helps fella
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    Sep 2011
    Grantham
    @neverlandandy TY for the picture attachment!
    Glue is a good shout actually. Think ive still got some araldite kicking around somewhere. That stuff is like concrete!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I would be inclined to replace it as it does not look good. Did you check the vacumn pipe that goes to the turbo for leaks/splits. (assuming its the same turbo as the 150)
    Best bet would be removing the heatshield for the Turbo removing the tube and checking it, it should have a protective silver metal around it. Not sure if you can get to it by removing the plastic undertray and look from underneath. also with the heatshield off you can see if there are any oil leaks or corroded bits
    Sep 2011
    Grantham
    The vacuum pipe to the turbo looks good. Checked all of these when I had the valve off. Theres also no oil or rust etc. The turbo itself is only 15,000 miles old.
    The internals of the valve seem all fine and dandy. Didnt really require cleaning. Whats alarming are the cracks. Think I may just replace it...found one on fleabay for not too much
    What about this as a replacement?
    http://www.ebay.co.uk/itm/1708943664...84.m1423.l2649
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I know that the 120 and 150 turbo are different part numbers but can you physically put the wrong turbo on and would it still run?
    Sep 2011
    Grantham
    Good question. I didn't fit the turbo. Anyone else shed some light on this?
  1. Opinion Please
    By gregc in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2010, 11:23
  2. hid opinion
    By baz_cdti_sri_150 in forum Styling
    Last Post: 9th July 2010, 13:03
  3. Need a second opinion - Do these look like...
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2010, 17:16
  4. I would like to have your opinion ...
    By hans_vledder in forum Styling
    Last Post: 30th January 2008, 23:33
  5. Your opinion please ...
    Last Post: 31st December 2007, 16:37
