Thread: Alternator changed now strange whirring noise and engine light on HELP !!
    argyll, scotland
    Default Alternator changed now strange whirring noise and engine light on HELP !!
    Hi all changed my alternator last night charged the battery up, started a bit lumpy so went for a run car seems fine to drive but i can hear a faint whirring noise when revving and my engine management light has stayed on aswell, any ideas what this could be ?
    The car sat with the battery and alternator disconnected for about a week while i waited for the new one to arrive
    car is a 1.9 cdt1 150
    argyll, scotland
    i also had the egr off and boost sensor for a clean, could this have caused the light ?
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    Read the fault code to find out what it is. Only way without guessing.
    Where is the noise coming from. Find a bit of pipe and hold it to your ear then try it in various places and all pulleys to listen for the source.
    Did you change the aux belt when doing the change. Could be tighter belt putting a bit of force against one of the pulleys ?
    argyll, scotland
    managed to get rid of the light after a good blast and double checked all connections, didnt change the belt just used the same one also noticed a slight tick every so often coming from the direction of the alternator like a sparking noise
  1. Strange whirring motor noise
    By stuball in forum Troubleshooting
    Last Post: 5th December 2012, 22:50
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Strange ticking noise coming from alternator area?
    By monty2000 in forum Engine & Drivetrain
    Last Post: 16th July 2012, 12:21
  4. Strange Engine Noise
    By CraigoT in forum Engine & Drivetrain
    Last Post: 13th November 2011, 18:08
  5. help please changed alternator belt now getting loud noise
    By deano1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 22:42
corsa c alternator whirring noise
