Thread: Cooling Fans
    Jan 2010
    Wigan
    Default Cooling Fans
    I have a 56 plate 1.9 cdti Signum with Air con, my question is there are 2 cooling fans on the rad is one conected to the air con system or just a boost fan for cooling the rad??
    The reason I ask is the right hand one as you are looking at the front of the car is running constant even when I turn the engine off, I have to remove the fuse to stop it. Just wondering is this air con related or coooling related.
    Thanks for any info.
    Ste
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    You answered your own question lol. Ones air con and ones a cooling fan.
    Could be the main cooling fan having an issue with the tempt switch and staying on perm ?
    Jan 2010
    Wigan
    Quote Originally Posted by Gavin2.6 View Post
    Thanks Gavin but which is which?? I'm havin problems with the right hand side one as you look at the front of the car.
    Liverpool
    Cant remember which is which but never heard of the air con fan staying on where as the cooling fan is pretty common.
    If the temperature sensor goes open circuit or disconnected the fans will come on as a safety feature. Also if the control module installed on the radiator fan housing dies the same will happen. Is the wire on the sensor on the thermostat ok and check the wiring on the rad itself.
    You could try find a friend with same car and swap out the control module to see what happens ?
    Jan 2010
    Wigan
    OK Thanks for replies Gav, I was thinking and hoping (cheap fix) it was the temp sensor but after today I'm confident its not i've had the spark at work today do his stuff with it and he's 99% sure its working also the gauge on the dash is reading ok and i'm thinking the same sensor sends the signal to the temp gauge also which would rule it out. After searching other similar threads I'm leaning towards the control module on the back of the fan, I have a mate with an astra same engine so might twist his arm!!
    Cheers again for your help.
    Ste.
  1. Changing dual cooling fans
    By Jonsey in forum Engine & Drivetrain
    Last Post: 4th July 2011, 21:59
  2. Engine Cooling fans working correctly?
    By luke4487 in forum Engine & Drivetrain
    Last Post: 28th April 2011, 11:15
  3. Radiator cooling fans – intermittant on/off - not at temp
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2010, 22:22
  4. Cooling fans run constant - Vectra c 3.2 V6
    By pawlo in forum Troubleshooting
    Last Post: 30th January 2010, 20:04
  5. Cooling fans
    By Darrell Lossau in forum Troubleshooting
    Last Post: 3rd February 2009, 22:18
radiator fan motor not working vectra c
p4184-3 cooling fan vectra c
cooling fans on constantly when temp switch is disconnected vectra
vectra c cooling fan stays on
p4184 vectra
if i disconnect ect sensor on vectra c should cooling fans work
vauxhall vectra fan staying on
disconnected temperature sensor but fan still running vectra c
vectra c radiator fan stays on
vauxhall vectra cooling fan stays on
vauxhall zafira rad fan and aircon fan staying on
