Results 1 to 10 of 15
Thread: 245/35/19 tyres and lowered on -30 mm eibachs - What spacers?
    Full Member RichM's Avatar
    Bracknell
    52 Post(s)
    Default 245/35/19 tyres and lowered on -30 mm eibachs - What spacers?
    Hi guys,
    Been thinking about some spacers to finish off the look of the car outside. If read a bunch of threads on here and am seeing mostly positive things. Question is, what size for the front and what size for the rear? I don't want the tyres to protrude past the arch at the top so was thinking 20mm on rear and 16mm on the front? Is it OK to mix them like this?
    Going on this...
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    i wouldnt bother if i were u mate. ur car is perfect!
    Regular Member travec19's Avatar
    Jul 2010
    Vehicle : Insignia
    Year : 2010
    Why bother, that is one tidy veccy, stunning.
    Bracknell
    52 Post(s)
    You can see it better in this older pic, I'd like to fill a bit of that wheel arch gap at the top but don't want it to look silly...
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    someone posted up yesterday having done this ,they liked the look of cavemanniges siggy
    20 Post(s)
    Vehicle : Vauxhall
    Engine : 1.9cdti
    Year : 07
    think the front was possibly to much at 20 .
    http://www.vectra-c.com/forum/showth...hlight=spacers
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    If you're going to mount 235 mm wide tyres, you'll install at least 8" wide rims. They'll have a lower ET, meaning they'll naturally protrude more, both to allow keeping the wheel centered and to keep it away from the wheel arch.
    Here is how mine looks with 235x35x19 on 19" x 8" ET 35 Irmscher Delta, WITHOUT any spacer :
    The original rims are 17" x 7" ET 41, so they have more inward offset than the ones shown here.
    Maybe you could consider a spacer might still be welcome, but 20 mm would definitely be too much : there are hardly 5 mm left out of the wheel arches. Having them protrudring anymore would render the car illegal.
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Both myself and lee Mark smith have run or are running 16 front and 20 rear. However i had to remove my fronts when i fitted lowered shocks with 45mm lowered springs. The rear i run with 245 but i do get contact sometimes. The ones lee are using are 22mm. But with 235. Oh and wd are both on flakes. Looks much more aggressive
    Apr 2008
    Noumea
    14 Post(s)
    Trim : Elegance
    Mileage : 75 000
    And how's the handling ? Won't the car understeer ?
    The 8x19ET35 respect the same central plane position than the original 7x17ET41 (I've calculated), so they don't stress the knuckles.
    Jun 2009
    bradford
    Handles very well ! steering is more precise and i have been running spacers on rear for about three years. No prob with wear on tyres or suspension
  1. Fitting Lowered Eibachs
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 12th March 2010, 11:29
  2. Replies: 17
    Last Post: 6th March 2010, 22:36
  3. 1.9 CDTi (150) XP NAV lowered on Eibachs
    By MCD in forum Quick Photo Album
    Last Post: 6th March 2010, 16:08
  4. lowered on eibachs
    By vanquis1979 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2009, 06:21
  5. Eibachs
    By lizard in forum Handling & Braking
    Last Post: 14th August 2008, 08:23
