Thread: Replacing cim ?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    Default Replacing cim ?
    Just after a little help, I've got my airbag light on and it's reading high resistance on circuits 1 and 2 drivers airbag, I've tried a different bag so now I'm left with the rotary switch (clock spring) as far as I can tell this doesn't come seperate to the cim ? Please correct me if I'm wrong.
    if I do need to replace the cim is there anything specific I need to know like does I need programming to car ?
    The car is a late 2004 vectra half can.
    Regular Member mat_splat's Avatar
    May 2012
    Frimley
    you can split it from a cim, when i replaced mine i had to take the spring out of the new one and fit it to the board as they are different. you cant buy it seperately but you can dismatle one back to the board. The only problem may be the steering column position sensor which has a white ring on the boss, this may need to swapped also. Big job to do like that but should avoid the programming issue.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you tried cleaning all the usual points on the cim and the abs plug with contact cleaner
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    I haven't tried cleaning the plugs but I'm pretty sure they won't cause the resistance faults, I will check them out though.
    Regarding stripping the clock spring from another module how simple is it to do ? I've not stripped mine down yet so haven't had chance to look.
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    If I have to replace the cim does the ignition barrel come out of do I need a new barrel ?
    Full Member Sebastian's Avatar
    Electric Heated Recaro Leather
    35 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by Mr Owens View Post
    It comes out easily
  1. replacing the REC
    By les287 in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2011, 04:14
  2. egr needs replacing?
    By family guy in forum Engine & Drivetrain
    Last Post: 20th April 2011, 10:41
  3. Replacing Tie Rod and Tie rod end
    By chazuwe in forum Troubleshooting
    Last Post: 25th March 2011, 13:46
  4. Replacing the CIM
    By Martyn21 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 18:22
  5. Replacing DMF
    By RikD in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 21:55
