Results 1 to 10 of 11
Thread: Things I Checked And Did Cheaply.
    Regular Member leighhockey's Avatar
    worthing
    Default Things I Checked And Did Cheaply.
    I did all of these cheaply with basic tools. try these if you have performance issues or hesitation then let the Knowledgable folk of Vectra C Forum help you if still at a loss.
    £8.99 From Halfords
    Airbox Mod
    Sensor with a blue sticker and yellow tab. remove clean with care.
    top view of the EGR valve, on the end is a connector remove to test.
    I personally blanked as you can see here but you decide.
    Vacuum Hoses 1m metre of hose like mine is roughly £2.ps i have 4mm on there at the moment but think the correct size is 3mm or 2.97mm to be super specific. but for 2 quid mine work fine for fault finding.
    This is the BCS, for ease unbolt and you can remove the top over from the little black box attached. remove filter test if it helps either replace, clean or run it without the filter. choice is yours.
    Injector 3, check the tab attached if yellow change. if not handy with electrics local VX should do it for £30-£40 which is nothing.
    I have done all of these along with a sillicone hose set from DPH Motorsport and combined my car has been transformed.
    these are a good starting point and learned how to do each of them from various how 2's on this site. im sure someone with better history of them will have the links to them but i will try myself to find and post shortly.
    Regular Member messermitch's Avatar
    Aug 2009
    Yorkshire
    Engine : 1.9Cdti 150
    Top job matey..
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    Good job lad. Great satisfaction doing these things yourself.
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    May 2011
    luton
    Wikid right up mate - and btw its halfrauds! Lol
    worthing
    thanks guys i just see alot of the same posts regarding these, was thinking someone who has been here a while can hijack this and make it a sticky with the right title or something.
    Regular Member pompey-pimp's Avatar
    Nov 2009
    Fareham Hampshire
    Vehicle : BMW 520D Touring
    Trim : M Sport Business
    Engine : 2.0 d
    Year : 2010
    Quote Originally Posted by SHIBZ X View Post
    I've found Halfords pretty good and reasonable, even better with a trade card. The tools are good quality and give you a lifetime guarantee.
    worthing
    halfords works for me to pick up little bits and pieces. i did see an offer on mobil 1 in there few days ago and ment to get some for my next oil change doh.
    Aug 2012
    Dunmow, Essex
    nice write up,
    I see that the blanking plate for the EGR is in the bottom of the valve and not in the metal corrigatted pipe, is the picture shwon the best place for it?
    i have a 1.9 cdti 120 BHp, just to be clear.
    cheers
    worthing
    well this is one type of blanking plate I did however today make One for between the manifold and the egr valve
    so now the egr has no flow at all going into it.
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Hi My injector tabs are all yellow so i take it i need to change mine have you got a part number for this ??
    Thanks Mark
  1. Everybody got their Antifreeze done/checked?
    By puppet in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2012, 13:41
  2. Ever since i checked the fuses.....
    By johnseffs in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2012, 11:58
  3. Should've checked Vectra-C.com
    By BigWilko in forum General Chat
    Last Post: 26th February 2010, 21:16
  4. Anyone checked out the Saab Aero X?
    By nutron in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2008, 20:15
  5. Getting my rear end checked
    By Flyingkiwi in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2006, 23:25
