Results 1 to 10 of 22
Thread: Possible EGR valve on 2.2???
    Regular Member Casper85's Avatar
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Engine : 2.2direct Z22YH
    Mileage : 54600
    Default Possible EGR valve on 2.2???
    Hi guys,
    Today I took what I thought was my EGR valve off my Vectra 2.2direct to see if it needed a good clean out and possibly make the emission light go out.
    As I was unbolting it coolant started leaking out. Could someone please confirm if this actually is an EGR valve??? If it is, should the coolant of leaked out?? But if its not, then what is it???
    Hopefully my attached photos have worked, I have took some of the piece I took off, where I took it off from and also how much coolant is left. I must note that there was a piece of thin metal in between the engine and this EGR??? that I did not photograph. Any words of wisdom gratefully appreciated!!016.JPG017.JPG018.JPG019.JPG020.JPG021.JPG
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    rushy is your man for this question m8.
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    Ok, is there any way I could send this thread to 'rushy' for him to look at??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Casper85 View Post
    pm the link to the thread.
    Blantyre
    Yes that's the EGR mate , I did the same on my 2.2 last week , but I didn't open the casing
    Sent from my iPhone 4s using Forum Runner
    Jun 2012
    Edinburgh
    any improvement after cleaning?
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    I haven't put it back on yet as I need to find out why the coolant was leaking out of it
    Regular Member Paulwr's Avatar
    Mar 2012
    Ormskirk, Lancs
    Vehicle : Astra H 1.8 VVT
    Trim : SRi XP 3dr
    Engine : Z18XER
    Mileage : 12k
    The EGR on the 2.2 is water cooled so when you took it off the water leaked from the cooling channels in the castings. If you put it back on correctly it should seal up water tight again.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Quality yes it's the egr fella as said above its water cooled
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Received your pm mate and as the guys have said that's perfectly normal as the egr is water cooled. If your egr is working fine then there's a cheap and easy way of blanking it if you wish with no side affects and no mot problems either.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
vauxhall 2.2 cdti egr water cooled
