Thread: Replacing faulty REC on a vectra-c estate 2005 model
    Feb 2012
    Norway
    Eek Replacing faulty REC on a vectra-c estate 2005 model
    Hi!
    I have a faulty REC (Rear Electrical Center, also know as the rear fuse box) due to short circut of my licenseplate lights.
    Found one with identical partno and Ident (EZ) on a local salvageyard, that I bought. I then went to my local Opel-dealer to have it programmed to my car. (Rear hatch on my estate did not work after replacing the REC). But to my surprise they claimed that my new part was useless, since it was not cleared from the donor car. Without it beeing cleared they where unable to program it.
    I have the VIN no from the donor car, but they said it was impossible to clear/factory reset the REC once it was removed from the donor car.
    Is this actually the case?? Or is my local dealer trying to rip me off, forcing me to buy a new part?
    They quoted me £1000 for a new REC (Yes, I live in Norway, and everything is expencive here, but give me a break!!! )
    Hope someone here could shed some light on this matter.
    -Finn Andersen
    Oslo, Norway
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    if you have the vin no. from the used part they can order themselves the car pass with security code to unpair it and then re-pair it to yours, i've done this several times on other uniits..
    Feb 2012
    Norway
    Ok, thank you for this quick reply! Just to be 100% sure I understand... The approach you describe is possible without access to the donor car? (it's allready on it's way to become nails)
    -Finn
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yes if you can find the VIN ten the dealers can find the code and unpair.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    If it is a dealer, then they will be able to read the security code from most components using Tech 2, 3 or later software.
    If you PM me the VIN number, I shall see if it is on my database.
    (before anyone asks, it does not cover uk models, just parts of mainland Europe)
    If your VIN is on my list, I will PM you any details that I find.
    If you then give the security code to the dealer , he WILL be able to divorce it from the old security set-up,
    He can then pair it into your car with you own car pass code.
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I had a look in both my databases, and also my VIN to code converter program..
    I am sorry to say that the VIN number that you supplied was not recognised / not listed.
    It was worth a try, but unsuccessful today.
  1. Vectra 1.9 cdti 150 2005 model
    By chay6684 in forum Engine & Drivetrain
    Last Post: 21st August 2012, 19:24
  2. 2005 vectra estate tailgate aghhh!!!
    By dilligaf@40 in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2011, 20:55
  3. 2005 vectra sri cdti 120 satnav model
    By Turbomanrony in forum Cars for sale
    Last Post: 2nd October 2010, 17:08
  4. 2005 Vauxhall Vectra SRi 1.9 CDTI 150 Estate
    By Vectra_Power in forum Cars for sale
    Last Post: 18th March 2010, 17:46
  5. Vectra 1.9CDTI 150 estate 06 model
    By bar3ch in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2010, 19:57
vectra c rec
