Results 1 to 2 of 2
Thread: confusing P1112 fault code
    Regular Member Casper85's Avatar
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Engine : 2.2direct Z22YH
    Mileage : 54600
    Default confusing P1112 fault code
    Hi guys.
    What is the real description for code P1112???
    When I had my code read it came up with:
    P1112 - SWIRL FLAP STUCK OR SWIRL FLAP ADAPTION MALFUNCTION OR SWIRL ACTUATOR MALFUNCTION.
    But looking through the fault code list on this forum P1112 means INTAKE AIR TEMPERATURE (IAT) SENSOR CIRCUIT INTERMITTENT LOW VOLTAGE.
    So what does P1112 mean??? Do I have a fault with the swirl flaps or is there something wrong with the IAT sensor??? Only thing I could mention is that I noticed the emission light came on (after being cleared) when temp gauge was over 90 degrees, driving in slow moving traffic. I have a Vectra 2.2direct.
    Nov 2010
    yorkshire
    Hi Casper85
    I have just had the same problem with my 56 plate 2.2 direct. Apparently, its a common fault.
    I had the IAT sensor replaced for £120 by a local garage and this then flagged up the swirl flaps. I know its not cheap, but get vauxhall to look at it as they do a modification for the swirl flap problem. Cost me just over £500, which included full diagnostic, parts, labour and ECU re-set.. Hope this helps.
  1. finally found a solution to the P1112 fault code :-)
    By Casper85 in forum Engine & Drivetrain
    Last Post: 7th December 2012, 14:00
  2. P1112 code finally sorted??
    Last Post: 13th September 2012, 22:43
  3. Fault Code P1112
    Last Post: 6th August 2012, 11:12
  4. Hi CO and Swirl flap code P1112
    By silflex9 in forum Engine & Drivetrain
    Last Post: 22nd June 2011, 11:44
  5. P1112 fault code
    By lizard in forum Engine & Drivetrain
    Last Post: 2nd May 2010, 15:47
p1112 opel vectra
opel p1112
p1112 vauxhall vectra
p1112 fault code vauxhall
p1112 opel vectra c
p1112 vauxhall
https:www.vectra-c.comforumshowthread.php170242-confusing-P1112-fault-code
vauxhall signum fault code p1112
p1112 vectra c
opel fault code p1112
vauxhall zafira code p1112
p1112 opel
corsa c fault code 1112
FAULT CODE P1112
p1112 vauxhall zafira
p1112 code corsa cwhat does diagnostic code p1112 meanvauxhall zafira p1112 fault codep1112 opel zafira1112 diagnostic code on vectra 2.2p1112 vauxhall corsavauxhall zafira p1112VAUXHALL VECTRA P1113opel zafira p1112vectra c p1112 error
