Thread: Can limp home mode correct itsself? 3.0 turbo diesel
    Regular Member malk's Avatar
    suffolk
    Default Can limp home mode correct itsself? 3.0 turbo diesel
    Hi all,
    I was towing a caravan yesterday and the power went. It seemed like the brakes on the caravan came on but I had a similar problem when the turbo inlet came off last year (simple fix).
    Yesterday I pulled into a service station, checked under the bonnet - nothing loose, caravan brakes seemed OK and I don't remember seeing any warning lights at any time.
    Stressed out, had a coffee, came back and the car and caravan rolled down a slow incline with no power, so not a brake problem. Pulled back onto the M6 and drove another 150+ miles with caravan and no problem anfd what appeared to be full power.
    So question is, did I get into limp home mode which then reset itself after the engine cooled ? Not sure whether to take it to a garage as nothing is wrong at the moment but I'd hate to have it keep happening.
    (I might have had a similar problem early last year but put it down to the safety brake cable on the caravan, so maybe it does recur)
    has this happened to anyone at all ?
    West
    You would only get a limp home if the eml was showing on the dash
    suffolk
    So any ideas as to why the power dropped and I couldn't get over 50 m.p.h. and then it sorted itself ?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    If the fault was intermittent, then it have cleared when you turned off/on the car. Could be something as simple as needing to clean the boost sensor or something..?
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If their was no light on its not limp mode
    Quote Originally Posted by malk View Post
    The symptoms you describe are very similar to the early stages of a blocked SCV
    It is the season for this!
    Look at the front and back of the caravan, see if there are signs of black smoke having been ejected from the back of the exhaust
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Turbo veins sticking
    May 2006
    scotland
    I have had limp mode sometimes without any warnings having been triggered on the dash. You sure know when you are in limp mode, the car is dangerous when it comes to pulling out onto a busy roundabout. So, in my experienec anyway, his car could have went into limp mode and not triggered a warning light.
  1. Limp Home mode
    By gary_e in forum Engine & Drivetrain
    Last Post: 28th August 2012, 20:49
  2. Limp Home mode
    By Bredsticz in forum Engine & Drivetrain
    Last Post: 12th July 2012, 19:43
  3. limp home mode
    By FRANKA in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2011, 12:04
  4. (2.2DTI SRI)‘LIMP HOME MODE’ icon. Turbo stops working!
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 15:03
  5. Limp Home Mode
    By dud in forum Engine & Drivetrain
    Last Post: 10th July 2008, 15:06
