Thread: jerky acceleration on VXR (Z28net) low revs
    May 2012
    Denmark
    Default jerky acceleration on VXR (Z28net) low revs
    Hi there,
    Hope someone can assist.
    I recently purchased a 2007 VXR - with one (major) quirk...
    When running in 5th gear at around 2000rpm - and you push the accelerator, it jerks and looses a bit of power in s jerky motion. When running at higher revs it's fine, but at low revs and high gear (4-5-6) it seems to loose power short.
    I've just had new sparkplugs fitted, which didn't solve it.
    My mechanic then took his bosch tester, and suggested we went for a drive and then test each ignition coil to see if there were any erros (which he suspected from the beginning)
    But - it wouldn't let him read any data at this level, only "silly" things like idle speed, air inlet temp etc.
    Anyone here have any ideas? Rather than changing ignition coil one at a time, is there a smart way of testing it electronically? What do they do at the dealers - and what do you do ? :-)
    thanks!
    -Mads
    Regular Member amand's Avatar
    Feb 2011
    west London
    Fuel level?
    May 2012
    Denmark
    both on full and empty tank... tried this morning with 50km left in the tank, and just 1 hr ago with full tank - same same...
    Glasgow
    Sounds like one of the coil packs. Dealership diagnostics machines can access things like this no problems to narrow it down to whichever cylinder it is.
    May 2012
    Denmark
    is this the tech2 diagnostic?
    Glasgow
    Yeah think so mate, its far more advanced and reliable than alternatives. Not many places have it due to the cost of it, smaller garages go for snap on etc which often cant access certain parts of the car.
  1. Jerky at low revs
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 12th April 2012, 14:25
  2. Strange noise under acceleration 1.5-2.5k revs?
    By Thom in forum Engine & Drivetrain
    Last Post: 20th September 2011, 14:52
  3. No/poor Acceleration under 2.5k revs
    By Diesel Dan in forum Engine & Drivetrain
    Last Post: 16th December 2010, 23:44
  4. Jerky acceleration / Car with spanner light
    By danman487 in forum Engine & Drivetrain
    Last Post: 8th July 2010, 14:31
  5. High Revs and Low Acceleration on 1.8 Vectra
    By RavenRob in forum Engine & Drivetrain
    Last Post: 5th January 2009, 02:20
z28net jerks
vxr jerkey acceleration
