Results 1 to 10 of 17
Thread: need some advice, ice related
    Regular Member dahmich's Avatar
    cwmbran
    Default need some advice, ice related
    evening guys, need a little advice on the ICE side of things, im looking at removing the ncdc 2013, and fitting a kenwood double din in its place, figured i dont really the satnav as i dont do as much travelling as i used to. now the questions
    1: if i take out the stereo, what will work or not, what will be affected, (trip computer etc)
    2: does the stereo have to be divorced and how?
    3: what bits will i need, i know i need a facia adaptor to fill in the gaps thanks to vauxhalls great design (cough) and the right iso lead, any suggestions
    4: thinking in advance, what speakers and sizes are needed for upgrade, again i know of the adaptor kit to help the new speakers fit thanks to again the awkward shape, but what size speakers are others running? 17cms?
    cheers in adavance
    dave
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Hi buddy, answer to number 4.
    The vectra woofers are all 6.5in (17cms) and any 6.5 speaker will fit.
    However I advise against plastic speaker adapters; they never fit properly and end up cracking. Buy some MDF rings off of eBay
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    No devorce needed mate no the trip won't work and facia adapter and aerial adapter is needed
    cwmbran
    Quote Originally Posted by mickydoos View Post
    link me???
    cwmbran
    Quote Originally Posted by paulvectrac View Post
    so will any of the functions work at all..range??
    cwmbran
    bump?
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    i have a pioneer in mine, range consumption etc all still there, scroll through them using the left scroll wheel on the sterring wheel
    dont bother changing the speakers for now, the HU is the weak link, the std door speakers are susprisingly good but yes they are 17s
    you only need to divorce the stereo if you plan to sell it, jsut store it away somewhere in case you sell the car? thats what i did.
    Regular Member coldo's Avatar
    Scotland
    i am assuming that as you have a ncdc 2013your car is Half CanBus (three buttons on the wheel) and not Full CanBus (two buttons and scroll wheels).
    Depending which type you car is affects the answers...
    Based on the car being Half CanBus....
    A: If you by a BC (Board Computer) stalk and have it activated (Using Tech2 etc) you should be able to access most of the trip functions etc as you have right now.
    A: No. The radio has it's own security code which moves with the unit. Only full can bus CD30 etc models need to be divorced.
    A: You will need a facia adaptor, ISO stearing wheel leads, Aireal adaptor and a patch lead for your head unit. I would recomend connect2 leads as I have found them to be the best. Companies like dynamic sounds are realy good and will talk you through everything. Expect to spend £50.00 for all this top quality kit etc...
    A: Already answered... Fit MDF rings and consider dynomatting behind the speakers on the door skin to prevent vibration.
    If it's Full CanBus is different but as I said I think you will find your car is half canbus based on the current headunit you have.
    Hope this all helps
    cwmbran
    yes mines the half canbus system, and i have a stalk on the right hand side of the steering column that used to control the h/u, but since fitting the ncdc 2013, didnt work, so im guessing that will change back to working once the h/u is out...
    i have sourced the iso leads needed, but mdf rings? cant find them in the right shape or do they need to be adapted?
    cwmbran
    Quote Originally Posted by J P S View Post
    i was going to sell it, no need for two steroes and the cars going to be with me a long time (hopefully) as for 17's, got my eye on a few, but im stuck on the mdf speaker thing?
  1. HELP! HID Related!
    By Sharpy28 in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2012, 19:37
  2. Work related advice required
    By the_wave_rider in forum General Chat
    Last Post: 5th April 2012, 20:49
  3. What would you do (HiD related)...
    By Dan_BlackSRi in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2012, 19:09
  4. Exhaust related
    By a_boughtwood in forum Diesel Engine related
    Last Post: 20th May 2010, 17:13
  5. Mileage advice needed *not vectra related*
    By Andy in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2006, 09:18
