Thread: Connect USB cable to car battery without power socket.
    New Member Echelon's Avatar
    Jul 2012
    Thatcham
    Default Connect USB cable to car battery without power socket.
    Hi all
    I don't want to use the actual power socket itself, but want to connect a short iPhone 4 data cable to it, and create a charging port in the arm compartment. So both the front and rear sockets are free for other mischievous uses!
    Can this be done..?
    Feb 2011
    Selby
    No problem - take the car charger apart (this steps the voltage down from 12V to 5V and filters noise from it), and solder a wire to the point on the pcb that goes to the cig lighter centre connector. Connect this to the centre terminal on the back of the cig lighter socket. Take a wire from the pcb where it goes to the plug outer terminal and run this to the cig lighter outer terminals on the car.
    Or am I missing something in what you're trying to do?
    Jul 2011
    UK
    Year : 06
    Now this is a good idea can't ya just take the plug off and connect it to the cig lighter and feed the wire job done
    Feb 2011
    Selby
    USB = 5V. Car electrics = 12V. Connect the USB lead directly to the car electrics and you'll fry your iPhone. Need to adapt a car charger.
  1. HIDs do they need to connect to battery?
    By VikingLammy in forum Styling
    Last Post: 16th January 2013, 13:50
  2. Cig / power socket surround?
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2012, 22:17
  3. Power Socket in boot
    By DeeBe in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2012, 16:24
  4. 12v power socket
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 20:05
  5. Battery and Cable
    By IBarfoot in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2007, 08:22
usb cabel connect to battery Opel insignia
