Thread: fault codes
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    Default fault codes
    U2103 (00) no comunication with CAN-BUS (high speed)
    B3902 (00) Wrong immobiliser idenitfier received
    B0084 Right EFS Cirvuit High Voltage (electronical front impact sensor
    B0283 Pane break open circuit
    B2966 Driver doorknob circuit open or high voltage
    any ideas?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Is your alarm going off randomly ?
    Are there any faults on car ?
    If not i would ignore them
    Irmscher Insignia CDTI 130
    Jul 2012
    Scottish borders
    Nope nothing wrong with the car apart from the airbag light on, I think one of the errors is because I have a small crack at the bottom of the widescreen
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    B0283 is your rear window
    B0084 Circuit right or centre. EFS (electronic front crash sensor) voltage too high / too low " this will either be wiring under seat or seat belt pre-tensioners, get under your seats and make sure the plug under both seats are connected correctly.
    Have you changed seats recently ? might be best taking leads off battery and unplugging both connectors from under seat then re connect them..DONT DO THIS WITH BATTERY STILL ATTACHED THOUGH.
    Get someone to clear airbag light and see if it stays off.
    Jul 2012
    Scottish borders
    ive not long bought the car so i dont know if the seats have been changed, the airbag light is on yes and ive tried to clear it bit it just re-appears
    Nottinghamshire
    The fault won't clear until the airbag ECU sees that the cause of the fault has gone. Also your airbags and seatbelt pre-tensioners won't work until the fault is cleared.
    B0084 EFS (electronic front crash sensor) may refer to one of the two 2 front impact sensors located to the inside of the headlights. Presumably 'right' means the offside one...
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    Quote Originally Posted by James24 View Post
    Sounds like the car has been crashed and not properly rebuilt..
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
vauxhall vectra fault code b0283
Opel B0084
vauxhall vectra fault code B0084
Vauxhall DTC B0283-05
B0283 - Pane Break Open Circuit
Vauxhall B0283-C
Vauxhall U2103-C
vauxhall vectra code u2103
b0084-05 opel
b0084-71 fault code opel vectra c
Opel B0283
vauxhall fault code b0084-05
crash sensor high voltage vauxhall
b0084 esf opel vectra c
b0084 bsf opel vectra c
b0084 opel vectra c
Opel B0084-71
