Results 1 to 3 of 3
Thread: 1.9cdti fuel filter housing leak ?
    May 2008
    newcastle
    Default 1.9cdti fuel filter housing leak ?
    Hi,
    has anyone had any issues with the fliter housing leaking from the quick release fitting on the outlet side of the housing, mines weeping diesel, i've had the pipe out & the blue plastic bit seems ok so it must be the seal in there that's goosed. don't know if the seal can be replaced or its a new housing ?.
    John.
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Quote Originally Posted by john1 View Post
    Hi,
    John.
    I think there is only a little O ring in there - you should be able to replace that
    May 2008
    newcastle
    i popped into VX tonight on the way home & the guy in the parts dept recons i have to buy the whole housing, it's not cheap £100. think i'll be looking round a breakers yard..
  1. Oil filter housing leak.
    By Nez in forum Engine & Drivetrain
    Last Post: 12th December 2012, 16:31
  2. Fuel filter housing removal - 1.9CDTi
    By AlexGSi2000 in forum Engine & Drivetrain
    Last Post: 7th July 2012, 17:08
  3. Fuel filter housing leak any suggestions?
    By Toe-side in forum Engine & Drivetrain
    Last Post: 11th March 2012, 12:00
  4. Fuel leak from filter housing
    By tom_nw in forum Troubleshooting
    Last Post: 5th December 2010, 23:27
vauxhall vectra c fuel filter leaking
vectra c 1.9 cdti fuel filter housing
my opel 1.9cdti is leaking petrol from the fuel filter
fuel filter housing vectra c
1.9 cdti fuel filter housing removal
https:www.vectra-c.comforumshowthread.php170169-1-9cdti-fuel-filter-housing-leak
opel 1.9 diesel leak filter
vectra c cdti fuel filter housing seal
vauxhall vectra 1.9 cdti fuel filter housing
vauxhall vectra fuel filter housing seals
zafira cdti fuel filter housing
vectra c 1.9 cdti fuel filter housing leaking
vectra diesel filter leaking
vectra cdti fuel filter leaking
