Thread: Little puff of Blue smoke on startup...
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default Little puff of Blue smoke on startup...
    The CDTi I have put a deposit down on, when started up (it was cold) gave a little puff of blue smoke, the inlet manifold is goosed (and will be replaced), would this cause the blue smoke..?
    Also, on the back on the manifold, there is a rubber pipe that is coated with some oily substance, what is this..? Its at the back of the manifold, just on the left of centre.
    Cheers in advance
    How long had the car been sitting before initial starting?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Not 100% sure, but not too long, probably 24 hours I would say (they had only just got it in this weekend).
    Possbly manifold - if it's shot then it's probably coked in oil/crud deposits. If left for a while, they could dry and probably break off fairly easily when the engine is started (airflow/vibration) and would burn blue when they passed through the cylinder.
    See if it happens when the manifold is changed, and ask if they're doing the EGR valve too. Either way, get them to blank it when they put it back together so it never even sees crappy EGR gasses, then get Ben to do his magic...
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Penfold101 View Post
    That's the plan, we'll see when they have done it, and I have the EGR blank all ready to be fitted in the garage at home
    Off at a tangent - I used your polisher on my Insignia the other day mate; feel free to check out the thread...
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Disconnect the EGR valve when you pick the car up after the dealers have sorted the manifold. That should limit the gases at least until you get that blanking plate on.
  1. SRI CDTI 150 Blue smoke on startup
    By sukyb in forum Engine & Drivetrain
    Last Post: 15th February 2011, 13:47
  2. SRI CDTI Blue smoke on startup
    Last Post: 8th February 2011, 12:01
  3. Blue Smoke on Startup SRi CDTI 16v Help !
    By Tim in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 19:09
  4. Puff of Smoke
    By MrBond in forum Electrical & ICE (including SatNav)
    Last Post: 20th August 2008, 11:30
  5. White/blue smoke at startup
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 27th March 2008, 08:57
why does my vectra have blue smoke on startup
