Results 1 to 2 of 2
Thread: 2.0 dti 2002 limp mode
    Aug 2012
    Durham
    Default 2.0 dti 2002 limp mode
    hi guys, im having trouble with my car, it started when driving i get to about 60-65 and it goes to limp mode, if i stop and turn ignition off n start car alls well until it happens again, more recently it some times happened 3 or 4 times moving away from a junction, i can drive around town and stuff no problems, plugged my opcom in and codes i got are p0340 cam position sensor circuit malfunction, p0335 crankshaft sensor circuit range/performance, p0300 high pressure diagnosis malfunction, p0380 glow device circuit high voltage, ive changed crank sensor but problem still present, and ive read some posts that these dont have cam sensors, is that right? ive also read that it could be my fuel injector pump for some reason, so hope it isnt that, any help would be great cheers lads
    Regular Member Suffolk Boy's Avatar
    Apr 2008
    NEWMARKET
    Vauxhall did a recall on mine which is 2.2 dti sometime ago , mine was doing same , phoned Vauxhall they took it in did recall , think it was ECU adjust and has been fine since . Give them a visit .
  1. Limp mode.... Help
    By jodiexii in forum Y & Z30DT Specific
    Last Post: 2nd July 2012, 09:45
  2. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  3. Limp Mode
    By Slippery in forum Engine & Drivetrain
    Last Post: 19th April 2009, 13:22
  4. Limp mode?!
    By JimNZ in forum Electrical & ICE (including SatNav)
    Last Post: 27th March 2009, 09:57
  5. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 10:34
