Results 1 to 3 of 3
Thread: 2.2 DTI Elete engine bay wireing diagram or ecu pin connector
    Jul 2012
    Telord
    Eek 2.2 DTI Elete engine bay wireing diagram or ecu pin connector
    hi this is my frist post but i am in deep trouable got P0110 and P0105, p1105,
    changed baro sensor , airflow meter , all vacum pipes and turbo intercooler pipes just got my ecu back from testing thats ok
    any ideas ? need to find a wireing diagram for the engine bay or pin layout for ecu.
    Oct 2010
    nr leeds
    Remove the upper inlet manifold, take out the boost sensor an gently clean the filament with a solvent and a cotton bud. Then while it's out give the manifold a real good clean out our with a degreaser. Just be careful with the other sensor which is attached to the soft stop butterfly in the manifold it doesn't like being removed. Is the engine cutting out when the light comes on?
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    fairly certain my 2.0 dti was giving p0105 & p1105 when the boost sensor needed cleaning , so worth a try , as said above .
  1. 1.8 engine loom wiring diagram
    By Wacky77 in forum Engine & Drivetrain
    Last Post: 6th January 2012, 23:08
  2. Engine wiring diagram
    By cybergen in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2011, 17:57
  3. anyone got an exploded diagram of the z19dth engine ?
    By roswell in forum Engine & Drivetrain
    Last Post: 2nd November 2010, 13:24
  4. Engine wiring diagram
    By Ken Edmonds in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2009, 17:02
  5. Disconnected connector in engine ??
    By dinac_cro in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2007, 16:37
vectra c ecu wiring diagram
vectra c engine wiring
vauxhall signum 2.2 wire diagram
vectra 2.2dti engine wiring diagram
2.2 dti ecu pins
2.2 dti ecu pins out
dti pin in engine
Ecu wiring for 22dti vectra
vectra 2.2 dti wiring diagram
zafira 2.2 dti engine loom diagram
zafira 2.2dti wiring harness
zafira 2.2dti engine wiring diagram
opel vctra 2.2 dti ecu pinout
