Thread: Air con help
    Jul 2012
    Warrington
    Default Air con help
    hi baught the vec about 2 weeks ago the aircon doesnt work or doesnt get cold the light on the disply comes on just no temp change is there a common fault to check for any help be good guys and its a 2002 2.2dti ls cheers
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    it may just need a regas for about 50 pounds at kwik fit
    i got mine done at nationwide autocentre they can test if you have a leak
    hopefully thats the cheapest option
    if not it maybe the compressor or condensor
    here is a thread here click below
    http://www.vectra-c.com/forum/showth...on-the-way-out
    its common on the vectra c
    Jul 2012
    Warrington
    got it booked in with my mechnic monday for a test and regas im hopeing that will cure it cause this heat is killing me lol cheers for the reply
    Jun 2012
    Midlands
    I get mine tested, regassed, with dye put in so spotting a leak in future is easier for £35 trade.it should just need a regas mate and all will be well again.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    It depends if it holds pressure after the re-gas.
    I would check for leaks first -
    If it doesn't hold pressure, then the most likely culpret it the condensor. It will be pin-holed, and need replacing.
    A new condensor should be swapped with it's receiver drier.
    Approx £135 fo these, plus o-rings, labour and then, vac-out and re-gas.
    I had a new condensor and receiver drier fitted, and then a full vacuum and regas.
    Works an absolute treat now
    Jul 2012
    Warrington
    All fixed just a regas needed and only cost 25 quid at mates rates to big cool smiles now lol
