Results 1 to 10 of 20
Thread: Driving me mad - how to remove 12v point
    Wetherby
    Default Driving me mad - how to remove 12v point
    I can't get the front 12v point to unclip so I can remove it - no matter what I do I cannot move the two black clips that hold the thing in place. I've taken the ashtray out etc and I can get the underside of the power point (just about). I can't work out how to undo the clips. I've tried a search on the site but with no joy. Please help.
    Sounds like a job for Duncan he has had his out more times than a dirty old man !!!!!!!..........His interior that is !!!!!!
    Technical directors office
    1. Remove ashtray
    • Remove ashtray
    2. Remove cigarette lighter
    • Pull out cigarette lighter (heating unit)
    3. Remove cigarette lighter panel
    • Unclip cigarette lighter panel
    4. Detach cigarette lighter housing from illumination ring
    • Disconnect 2x wiring harness plug
    Note: Under the cigarette lighter housing, not shown in figure
    • Detach/lever housing/illumination ring
    • Remove cigarette lighter housing
    • Remove illumination ring
    Thats the gospel according to VX.....
    Have you missed any of those steps out??... The diagrams ( that i can't cut n paste ) show it coming up and out with a small screwdriver being used to lever it up over the 2 plastic spring clips....
    Wetherby
    Thanks.
    Where abouts was the screwdriver used? It won't shift.
    Quote Originally Posted by drinky View Post
    - it's true though!
    Exactly as Mark said, and the trick is the little screwdriver to just prise the lug things to release it. I'm sure Dennis the Menace had some pics somewhere on doing this.
    it was used under the lip of the lighter, after the top decorative panel and the lighting 'ring' was removed, it was just put in between the socket and the black underpanel to provide some lift.. it's only held in by 2 small plastic prongs..so you shouldn't be having the trouble you are....
    Ahh.. the 'gutter of interiors' is back here now.....
    Wetherby
    NOOOOO!! I've snapped the little collar that holds the spring cover. Oh Vectra why do you torment me so much
    Quote Originally Posted by Gsi3.2 View Post
    - still up on NE as it happens. Weather didn't look fun today so driving down tomorrow.
    Quote Originally Posted by sithompson View Post
    Oh bu**er!! Maybe a bit late, but let me dig mine out of the car and see if I can explain it any clearer.
    the spring cover is on the top plate, the decorative plate, that needs to come off 1st, before you try prising it out...that entire silvergrey panel needs removing in step 3....
    you're now tempting me to go outside again aren't you..... time to see what the bind is..
    EDIT:Just seen D's post.. so i'll wait a while and see what he post's up....
  1. Spanner light while driving to work with no code and usually same point when driving to work?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2012, 21:52
  2. Thanks for the one point
    By soulman in forum General Chat
    Last Post: 27th March 2012, 08:14
  3. Replies: 2
    Last Post: 28th July 2011, 13:37
  4. limp mode on motorway driving.....driving me crazy!
    By big rich in forum Diesel Engine related
    Last Post: 27th August 2010, 05:24
  5. AA driving school car + dangerous driving: Who to report to?
    By RSV_Ecosse in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 18:05
vectra c boot light not working
vectra c boot light has 2v when off
