Results 1 to 10 of 13
Thread: Boot light problem
    Cheshire
    Default Boot light problem
    Hi, this is my first post - so hope you can help.
    This seems such a minor problem that I'm loathed to take the car to the dealer to just have this corrected even though its under warranty. But the light in the boot does not work and its so annoying especially if looking for something in the boot in a poorly lit street/carpark! The bulb works fine as I've tried it in the glove box light, and the connections seem ok
    Is this light covered by a particular fuse (cant find a ref in the hand book) Cant even find a switch on the hatchback that conrols the switching on and off of the light so presume its controled by the hatch lock?
    Help would be appreciated!
    Ps Great Forum!
    Regular Member Modifications's Avatar
    Sheffield
    have you tried putting a volt meter on the plug to the light fitting and see if you get any volts. could be the fitting it self.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have you got to wires in the back of the light?
    EDIT, and to the site mate.
    Cheshire
    Thanks - will try the volt meter tomorrow, and yes there are two wires into the back of the bulb holder
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Don't forget the light powers down after a set time,so do your testing as soon as you open the boot.
    if there is no 12v feed to the light with the boot open, then try triggering the boot lock, to see if it gives the light any power..is that the only electrical thing that is failing to work in the boot area..
    Cheshire
    yes, everything else works great ie lock, wiper, heated window and light clusters.
    Is there a fuse to cover this interior light?#
    Thanx
    Bring it along to our little meet on sunday and i am sure we can sort it out for you !!!!
    the system picks up it's power from the rear body electrical centre, located in the passengers side of the boot compartment..check all the multiplugs are in place and secure..
    there is no fuse to this system on the wiring diagram...but have a look at the fuse's located within the rear electrical system to see if any have blown....
    Quote Originally Posted by drinky View Post
    Now theres an offer....
    Top man Drinky...
  1. Rear Signum Light problem problem - help
  2. boot latch problem
    By wallace78 in forum Insignia car chat
    Last Post: 10th August 2011, 10:56
  3. problem with astra boot
    By the fisherman in forum The 'Off Topic' room
    Last Post: 11th February 2011, 22:01
  4. Help!!! Boot problem!
    By alannorman10 in forum Bodywork & Interior
    Last Post: 11th February 2011, 21:57
  5. Problem with the boot
    By Dane in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2011, 13:44
vectra c boot light not working
vectra c boot light has 2v when off
