Thread: Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    Apr 2011
    Berkshire
    Default Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    Hi, I have just had a failure of a Z19DT engine in my Vectra Estate. The brake vacuum pump 'adaptor' (between the pump and the end of the camshaft), split in two and jammed the camshaft. The cam stopped turning, the woodruff key on the campulley sheared and the pistons met the valves.
    Anyway I can get a double overhead can engine but I'm not sure whether the original gearbox will mate to it, and what else, apart from the engine management system, I will need to change or modify.
    Any ideas gratefully received, many thanks.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    May be possible, but you'll need engine, loom, ecu, downpipe (i think), and i think the gearboxes have different ratio's on the 150 to the 120?
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    id assume that the blocks are the same and just the head and ecu details etc are different
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Quote Originally Posted by Krusty3380 View Post
    Hi
    Well there's differences between the two vehicles electronically and mechanically.
    It would be easier/cheaper to replace it with the correct engine.
    Gearbox
    Ecu's
    Fuse box (variant dependant)
    Various engine bay looms
    Exhaust system (inc turbo depending on year and variant)
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. 1.9 cdti 120 z19dt engine
    By roshaan in forum Diesel Engine related
    Last Post: 23rd June 2011, 23:31
z19dth can it replace z19dt
cam on z19dt www.vectra-c.com
vectra c woodruff key z19dt
z19dth vs z19dt
z19dt engine swap
is a z19dt engine the same as an z19dth
z19dt to z19dth
z19dt camshaft change
engine swap z19dt to z19dth
SWAP z19dt na z19dth
replace z19dt engine
