Results 1 to 10 of 18
Thread: loom / wiring harness auto: mirror, lights + rain
    May 2012
    Denmark
    Default loom / wiring harness auto: mirror, lights + rain
    Hi there,
    Well - I was lucky and won an auction with EX sensor + auto headlight switch, and also a rear view mirror with dimming (+ cover)
    I have looked through the how 2's - and there is a great one where you have the wiring done with some idc connectors etc.
    I am however not too confident with this type of electrical DIY, and would rather just run a cable and then take it from there..
    What part numbers do I need to get this to work, I've been looking at the OPELOEM site with no luck.
    Or - anyone got any for sale? :-)
    Just to clarify - both the wiring for the dimming mirror and the sensors need to go the back of the car?
    And when changing to the auto headlight switch, do I need to change anything in the back of this?
    thanks.
    br,
    Mads
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    From what I've read on here, the part number for the mirror harness is:
    24450051 (Hatch/Saloon)
    24455219 or 13174250 (Estate)
    http://opeloem.com/opel/vectra_c_200...r_harness.html
    Hope that helps
    Damo
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you will also need new roof loom for the rainsensor, if you want that working... or make up the loom.
    May 2012
    Denmark
    I was just out taking a picture of the REC (is that the right term for the rear fusebox?):
    The loom/harness marked in red - could this indicate that the wiring is in place for the rain/light sensor?
    If this is the case - could you then simply attach the dimming mirror to a "fixed" line (if present) by the lights?
    thanks.
    Year : 55
    Mileage : 92,000
    The auto dimming mirror plugs into the socket below the one you have indicated
    Engine : 2.2 Direct
    Mirror loom is in the lower as above.
    The top one, also goes to your interiur light ect. You will have to check above your light if you have a spare flat cabel saying "regen" or "regen sensor"
    May 2012
    Denmark
    cheers - I will check this asap.
    Engine : 2.2 Direct
    nipmads, i can see that you have 3 40 amp fuses in the REC.. if you dont have heated rearseats, then you can remove 2 of them and use as spare "konstant strÝm"
    May 2012
    Denmark
    Top tip
    Kenp: the luggage hooks you havd in the rear, where did you get a hold of this? Nice to have a large boot - but grocery bags tend to go flying everywhere...
    Engine : 2.2 Direct
    Got them from the german ebay.. think they where like 50,- DKK + postage but from here http://www.opel-nienhaus.de/index2.php (they sell on ebay, but you have to order via mail/paypal, as you live abroad to them)
  1. Auto dim mirror and rain sensor retrofit without GM loom
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 16th December 2017, 01:16
  2. Auto Dimming Mirror, Loom, Rain Sensor & Cover.
    By LeeU in forum Parts for sale
    Last Post: 30th December 2010, 22:25
