Results 1 to 10 of 19
Thread: 1.9cdti 150- seems to have less grunt once it's warmed up on a long run?
    Regular Member Craig1985's Avatar
    harwich essex
    Default 1.9cdti 150- seems to have less grunt once it's warmed up on a long run?
    Could this be start of a egr fault? All pipes look ok, egr and boost sensor been cleaned. Vauxhall couldn't find and thing and cars running latest software. Cars all serviced up to date, (36k) no smoke, and swirl bar is ok.
    Would Unplugging egr for few weeks help rule out the egr valve?
    CHESHIRE
    hi craig 1985 , had a similar problem for many years now , first drive of the day loads of grunt as you put it but next time you get in the car seems like its lost about 20% of its power , its like this untill left for many hours when engine has cooled rite down again , i allways but this down to the egr valve kicking in when engine has fully warmed up and yes it does seem better when unplugged ..
    West
    You will certainly do it no harm by unplugging the egr, i drive with egr unplugged permanently & only plug it back in for the mot, if anything you will prevent the swirl flaps from failing prematurely.
    CHESHIRE
    The only negatives I've noticed with unplugging the egr, is tad noisier and a tad thirstier.
    Regular Member leighhockey's Avatar
    worthing
    do you have an android? go buy and one of these http://www.ebay.co.uk/itm/USB-ELM327...item2a2021f43f then download an app called Torque you can read fuel rail pressure intake pressure turbo boost bhp etc best £10 i have ever spent plus i can clear fault codes and read them. examples of my readings on a post of mine http://www.vectra-c.com/forum/showth...150-Taxi/page4
    CHESHIRE
    hi leighhocky , not sure how that plug in part works does that just take readings from the ecu ?
    ps do i still need it if i have the android app down load ?? ..
    worthing
    you need the plug in part, it plugs into your obd port underneath your ashtray. you connect to it via bluetooth then it takes readings from your ECU.
    it also works on some other cars so is quite handy for helping friends. ps if your handy on your android you can find a torrent for the pro version of torque and install it dont know how much it is now.
    CHESHIRE
    Quote Originally Posted by leighhockey View Post
    ok leighhockey bare with me on this one a sec , write the andriod app bit , found one called "torque pro OBD to car " for £2.95 is that the one i down load ?
    also the plug in bit that takes readings from the ecu , were does the information come up is it on yeah phone do i need an app for this ?
    really interested in getting all this just want make sure i know what im doing cheers dave .
    Admin plasma's Avatar
    On the Forum
    187 Post(s)
    Engine : 150
    Mileage : 74000
    intercooler problem? air getting too warm and engine being retarded due to the temps?
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    West
    Quote Originally Posted by dave r View Post
    I can't say mines any noisier & I'm currently running 39.4mpg according to bc, that's 100% town driving with a heavy right foot... maybe you have other issues?
  1. how long do cambelts last on a 1.9cdti 150 (signum)
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 20:04
  2. How Long to heat Up for a 1.9CDTi?
    By boba in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2008, 20:22
  3. any 1 else got this wierd sound when ar warmed up!!!!
    By vectramad in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2008, 21:11
  4. very little low end grunt
    By cheekylemon in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2008, 16:57
  5. Weird noise and a lack of grunt
    By threelitresofelitesig in forum Engine & Drivetrain
    Last Post: 31st October 2006, 07:59
